Question about Electric Strider Maxi 4 Wheel Mobility Scooter - Cherry Red
Rover three wheel mobility scooter full charge horn working but just wont move
  • Electric Master
  • 1,263 Answers
First of all,
Make sure the freewheel lever is unengaged (up or down ?) , this can be tested by pushing the scooter forward , you should hear gearbox clunk,(Freewheel not engaged) Not all scooters sound a alarm when freewheel is engaged.
is the power indicator working okay,
Does the Wig Wam move freely, the thumb throttle part,
Check under the seat to make sure you have not blown or tripped the fuse, if it's a switch simply pressing the button will sort it, if not check the two prong fuse ,
you may also have some reset buttons on the stem so look out for them.
Now let me what you tried
Regards
GeWiz.
Posted on Jul 24, 2009
Green ready light on Pride Sonic three wheel scooter wont turn on. What turns it on?
Hi if it is similar to pride x the circuit will shut down if key is left on for 20 minutes u will still have lights. Remove key for a short time then replace it & turn on ..goood luck
Jan 21, 2016 | Pride Sonic 3 Wheel Portable Scooter
Ew36 scootor wont move
Hi Sharon,
out of 20 of those models I have repaired 2 have been a throttle fault however 10 of them where controller faults. are you located in the uk ?
Regards
Jan 03, 2016 | Electric Wheels Ew36 Mobility Scooter...
Why won't my mobility scooter go?
Three things you might try:
1. Make sure the charging cable is not plugged into the battery pack.
2. Make sure the transaxle is engaged. Try changing the position of the manual freewheel lever.
3. The "horn" also gives diagnostic codes. See if there is a repeating pattern to the beeps and compare them to the code chart.
Sep 19, 2014 | Pride Go Go Elite Traveller Plus HD 4...
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
My mom's Bladez DKS200 mobility scooter suddenly stopped working when she tried to take it up a steep hill. At first, even the battery light wouldn't come on, but after pushing the reset button, the...
Not exactly sure this is helpful, but make sure the bottom of the scooter is dry; all it takes is a little moisture and the scooter won't work.
Sep 16, 2010 | Electric Health & Beauty
Batteries are fully charged with the lights in front and horn working but the lights on rear and scooter will not move. Craftmatic Scooter. Three wheel.
Remove the seat and the plastic cover over the batteries. look at the lights in the cover or at the back of the scooter an see if they are plugged in. It is a common fault of when working on the scooter to forget to plug the lights back in on assembly. Hope thats what it is.
Aug 12, 2010 | Health & Beauty
4 whhel strider won't run, batteries charged
the motor is not working perfectly and chnge motor or check the connection perfctly
Jul 13, 2009 | Electric Strider Maxi 4 Wheel Mobility...
Have Zoom 220 HMV 3 wheel scooter. Charged battery in house socket. Shows green, turn key shows fully charged but will not move forward or backwards. Horn works.Moved don't have the manual. It is only 1...
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Jun 08, 2009 | Zoom 220 HMV 3-Wheel Travel Scooter
Electric Strider Maxi 4 Wheel Mobility Scooter - Cherry Red Logo
331 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
