Question about Samsung Televison & Video
Samsung SP50L6HD Tv turns it's self off. Time
Samsung SP50L6HD Tv turns it's self off. Time frame getting shorter between turning tv on and it turning off. Has been doing it for quite a long time. TV is about 3 years old. If you leave it off for a while you can turn it on again, but the time it takes to shut down again is getting shorter.
  • 85 Answers
Sir it may happen if the auto off option is enabled and the timer is enabled........... check for this options if they r and enabled then disable that........... or give your tv to the service shop and check for any problems
Posted on Jul 20, 2009
Samsung 26" LCD TV
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Jul 17, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
Can anyone point me in the right direction?I have had my samsung DLP (model SP50L6HD) for 4 years. This morning my children were watching TV and the tv started turning itself on and off. I switched it...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 24, 2011 | Samsung HLM507W 50" Rear Projection HDTV
My tv plays about 1-1/2 hours then shuts down
YOU WILL NEED TO REPLACE YOUR PROJECTOR LAMP #BP96-01472A AND THIS SHOULD RESOLVE YOUR ISSUE.
HOPE THIS HELPS
Jul 07, 2009 | Samsung HL-S5087W DLP TV
My Sony HD-TV KDF-50E2000 blinks 15 times pwr button then turns on. After about 2 hrs turns itself off and blinks 40 times then turns itself back on. shorter and shorter on time thoughout the day. No led...
Symptom shows Lamp is getting weak and its time for new Lamp in TV.
Lamp replacement procedure is written in user manual.
Please buy Sony original lamp for TV safety.
Thanks.
Jul 03, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
TV screen turned on for only 10-15 secs then self turn off, followed soon after by the tv power another 10-15 seconds later. if i try this a few times screen wont light up at all.Is it the TV Lamp?
1) Can be dust do a good clean
2)Check for the fuse and change it if needed.
3) Capacitor needs to be changed, you'll have to findout which one.
Hope it helps, good luck
May 19, 2009 | LG RU-52SZ51D 52" Rear Projection...
Samsung sp50l6hd projecton
If a “Check Fan” message appears on the screen:
Take a look at the fans while the unit is on. If a fan is not operating, check the connector to that fan. If the connection is good, replace the fan. If the fan is still not operating you have a problem with one of PCBs.
May 15, 2009 | Samsung HLN467W 46" Rear Projection HDTV
Hitachi 50" MTS TV/Monitor
It's possible you may have bad solder connections on the chassis boards.
C-Dog
Feb 13, 2008 | Televison & Video
Televison & Video Logo
631 people viewed this question
Henry  Thomas
Henry Thomas
