Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
Same problem really
Machine starts then error message usually around 126 minutes left then press start again and it will move on to 56 minutes then stopp again showing error code oe blockage or kinked pipe none of these are true have cleaned right through the system from filters sump pipe and one way valves in undersink plumbing which were clogged but still problem persists This LG machine has been a donkey since day one never dry's properly and cleans less than well and has lasted no time at all really If anyone knows the answer apart from scrap it I would be obliged
  • 103 Answers
With all these error codes but nothing paning out i would recommend replacing the control board inside of the door panel.
Posted on Aug 15, 2009
How to unlock a Maytag double oven
Hi Mary,If the door locked after you started the oven!
Press Cancel/Off key to start a latch reset, wait 20-30 seconds and open door, or turn the power off at the circuit breaker or fuse box for one minute, then turn the power back on.
If the oven has a manual latch handle!
Allow the oven to cool, approximately 30-90 minutes, move the latch arm to the left to unlock the door.
If the latch arm will not move after cooling to room temperature, or is stuck in between full right and full left positions, schedule service.
Is the oven door locked due to power failure during Self-Clean? If the oven door locked due to a power failure during a self cleaning cycle!
Select the "Self Clean" option, then select "Cancel". Wait a couple of minutes then try to start the cycle again.
If you started the oven clean cycle by mistake!
Press Cancel/Off key. The oven will need to cool to approximately 200F(95C) before the oven door will open.
Was there an error message!
Follow directions in the display, and refer to the Error Code Symptom, or:
Reset power to the oven!
  • Power the oven down by turning off the circuit breaker(s) or fuse(s) or if you can, unplug the oven for one (1) minute.
  • Turn the power back on turning on the circuit breaker(s) or fuse(s) or plugging it back in.
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify the ovens operation.
Kind regards
David
Dec 04, 2017 | Maytag Kitchen Ranges
F4 code
Usually the error codes are shown as like E4 which would be E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left. If you have any further questions or feel that the error is an F error code instead of an E error code message me back and I will look futher into your F error code but even if you click this link which will bring you to the brother error message site click here http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faqh/000000/000000/000064/faqh000064_000.html?reg=us&c=us&lang=en&prod=hf_ce5000eus&Cat=56 it still basicly says the same thing and the errors are shown as E's. I await your reply if you have any further questions Thanks Rick
Jul 28, 2011 | Brother CE5000 Computerized Sewing Machine
Hotpoint WF645 error message: test
press start once then press again then hold on/off and cancel for a few seconds should now turn test off should be ok now
Jul 15, 2009 | Washing Machines
Error Message
Your owner's manual may give a troubleshooting guide for the error code your machine might give you. Is it possible you have locked out the control panel? I "think" the calypso has a control lockout, usually a start button or cancel button. If you press it in for 3-5 seconds, it can lock or unlock panel. If all else fails, try unplugging it and see it it will drain out the water.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag neptune error? message
Unplug for 10 min to reboot the curcuit board. This will reset the system. Sometimes selecting numerous cycles or pushing buttons a lot in a short period of time can overwelm the little brain in the curcuit. This action will clear the memory of any unwanted comands in the curcuit.
Apr 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Bosch washing machine shows error code F37 and beeps
My Bosch washing machine shows error code F57 and beeps
Dec 09, 2008 | Bosch Logixx WFT 2806 Front Load...
F-11 code error.
sound like a control problem
May 24, 2008 | Kenmore Elite 45986 Front Load Washer
E70 error
May 15, 2009
I had this exact same problem with my Frigidaire washer (E70) as bubbles100. I called an appliance repairman on 5/14/09 and paid him $60 to tell me my hot and cold water hoses were reversed/not properly installed.
This repairman was the cheapest priced $60 and he would work till he found the problem. I had one appliance repair company wanting to charge me $90 for 30 min and another wanting to charge $120 for 30 min. Hopefully this information can help save the next person some money by trying this first.
Feb 16, 2008 | Frigidaire Affinity ATF7000E Front Load...
Error message
I can't find the "50" as part of the "Unable to print" error. Usually when you get "Unable to print", it means there's a torn piece of paper, paperclip, some foreign object in the machine somewhere. Check under the scanner lid and inside the machine, look thoroughly; you may find a piece of paper blocking a sensor. If the error message continues, follow these steps before disconnecting the MFC so you won't lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in memory: 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. ?OR? If faxes are present, you can transfer them to another fax machine. Go to Step 3. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1. Let me know if it helps!
Oct 02, 2007 | Brother MFC 210C All-In-One InkJet Printer
Sometimed error being displayed but also not completing cycles and not performing a fast spin
Hi there, I've also had this problem a few times. I've found cleaning out the filter can help solve the problem of the E20 message. Also when it doesn't spin fast it usually means the load is uneven. I found it happens with towels or bedcovers, heavier loads, if the load is uneven it will spin slowly for a good few minutes and then just stop with the clothes still dripping. I found rearranging the load more evenly usually sorts it out. I've had my machine for 18months now and usually love it. It washes and dries well, however, my dryer has stopped working again! I'd only had the machine 7 months when the dryer first stopped working another 11 months down the line and it's not working again! Hope this helps. Lelly2003
Oct 27, 2006 | Zanussi WJD1667W Front Load Washer / Dryer
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
119 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
