Question about Spidem Trevi Anthracite Espresso Machine
Gaggia Trevi will not heat up
I have a Gaggia Trevi Exclusive, when I turn the machine on the light flashes indicating the machine is heating up but does not go out and I cannot make coffee. The steam function still works just fin
  • 80 Answers
Check reset buton on tank,or maybe element dont work or computer board
Posted on Aug 01, 2009
Green power light only on trevi exclusive
When power is turned on, the coffee selection button should blink during warming up. If it is not blinking then the following i possible:
1- The electronic sensor is bad. It is clamp mounted on the boiler to sense temperature and send message to control board to turn the heating off when it is ready to make espresso. The blinking light will be fixed to display this.
2- The heating element on the boiler is bad and not heating. The electronic sensor cannot relay any temperature as it is.not sensing the heating.
3- The electronic control board is bad and not sensing the temperature.
The machine should be opened up to test the sensor or the neating elements, and replace what is bad..
Aug 31, 2014 | Spidem Trevi Automatic Espresso Machine
Doesn't heat the water Start...makes noise, the
the flashing heating light indicates that it isn't getting water. This could indicate that your pump has gone bad.
Oct 15, 2010 | Breville Die Cast 800ESXL Espresso Machine
Gaggia Syncrony won't heat up.
I switch the machine on and the green light (number 24) flashes to indicate it is warming up but it never gets there it just keeps flashing for at least half an hour.
Dec 31, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia trevi exclusive - one of the old black machines. We've not used it for a while and have just switched it on, it grinds the beans but no water comes out of the spouts or steamer. Chrissie
Hi
This might work. Its for a Saeco Vienna.
First off, don't leave the machine on for a long time if you don't have any water flow.
If its been setting for a long time you might have a stuck check valve in the pump.
The best way to prime the pump is to put in test mode.
Turn the machine off. Push and hold the 2 right buttons at the same time. While holding them down, turn the machine on.
Release the buttons and turn the dial counter clockwise till it stops.
This will keep the machine from heating.
If you push the center button the pump will activate.
Open the steam knob.
If you don't have your old priming pump, you can use a bulb aspirator.
Remove the water tank and fill the bulb with water. Insert the bulb into the hole on top of the machine where the tank was.
Push and hold the center button and squeeze the bulb to force water into the hole. Sometime it takes 2 people to prime the machine easier.
If the bulb squeezes easily and water flows, you did it. If not keep trying. You may have to remove the pump and blow some air through the small end (intake side) with an air hose.
Nov 28, 2009 | Coffee Makers & Espresso Machines
I need to final a set of Instructions
Check out this site they have a selection of manuals.
http://www.espressotec.com/store/pc/Support-Manuals-c12.htm
Sep 15, 2009 | Gaggia Titanium Espresso Machine
No water for brew
Remove the brew group and clean the shower screen at the top. This might be blocked.
Jul 13, 2009 | Spidem Trevi Anthracite Espresso Machine
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Evolution Espresso won't heat up
1 heating element defect(needs replacement)
2 security termistat, (replacement or reset)
Mar 25, 2009 | Gaggia Evolution Espresso Machine
Spidem Trevi Anthracite Espresso Machine Logo
489 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
graybeard32301
ray gallant
nikolay nikolov
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
