Question about Ovens
No manuel for Teba oven
Hi there.
Have shifted into house with teba stainless steel oven and stove top.
I need abit of help understanding oven dial.
It has 6 settings;starting at the left:
1.Zigzag part way down oven
2.zigzag at top of oven
3.Line at top and bottom with fan in middle
4.Lines top and bottom
5.fan in the middle with circle around it
6.just fan in the middle
If u can shead any light on this me and my cakes would greatly appreciate it. =)
5 Suggested Answers
  • 215 Answers
SOURCE: where can i get a manual for a built in teba fan
Try pressing the stop/cancel button, this should clear the error, if this does not work unplug for 5 minutes and then plug back up , this should clear the display and the oven should work.
Posted on Nov 15, 2009
SOURCE: user's manual for venini stainless steel wall oven
this is a defrost option. it runs just the fan to defrost things quicker - do not turn oven temp dial on when using.
Posted on May 12, 2010
SOURCE: Can't decipher the symbols on my convection oven
Here is the manual. Hope it is not too late. Lol.
http://www.aristonbrand.com/downloads/MB91IX%20-%20Instruction%20Book.pdf
Posted on Mar 04, 2011
Teba electric oven not heating up could it be timer .? Or element? Where can I get a free manual
Posted on Jul 01, 2011
Frigidaire Gallery 30'' Freestanding Electric Range We recently bought a house with this stove in it. however the oven door outside window part is off.....how can we re-attach it.
Hey Alice, I appreciate your post!
I understand that you need help reattaching part of your Frigidaire range. I have located a parts schematic and attached it for you. If you need any additional assistance please feel free to reconnect. Good luck! -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995639282.pdf
Dec 20, 2015 | Frigidaire Gallery 30 " Stainless Steel...
Is there an internal fuse in my Stoves Teba Electric cooker?
google the mfg's website and ask tech support
Apr 02, 2015 | Stoves Ovens
The oven will not work, power is on, stove top works, light works, display is off, no heat. The control lock and delay feature is not set
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 10, 2011 | Whirlpool GBS309PVS Stainless Steel...
Where can i get a manual for a built in teba fan oven. It has reset itself and the timer switches off after 2 minutes and I cannot reset to not use the timer so cannot cook anything in the oven.
Nov 14, 2009 | Ovens
Oven beeping
hi my kenmore stainless steel black top keeps making a beeping sound and says F11
Sep 03, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Know display anel getting EXTREMELY hot
Laura_kucari
I think you are feeling the heat coming from the oven vent. The fan still runs as it tries to cool down the temp in the compartment housing the electronics.
Regards
Aug 31, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
GE monogram double oven display getting extremely hot
Usually the knob type controls uses the bulb for temperature regulation. There is usually only one adjustment available - otherwise the thermostat has to be replaced. - that dial with the temperature graduations on it. the whole unit - the bulb in the oven is connected to it.
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Smeg se375mfx5 / stainless steel
i suspect you took the door off without locking the hinges
you will have to put the hinges in the lock position before putting back.
lay door on a blanket with hinges upwards. force the hinges back and bring the locking arm up to lock the hinges.
this requires considerable strength
Jul 05, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
1,195 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
