Question about Nokia 5200 Cellular Phone
Unable to send sms messages when i try to send a message it just says message failed and saves message to be sent
  • a_major2 Jul 20, 2009
    what should the message centre num be? not sure of this thanks
    i have a virgin sim if that is any use
  • 1,272 Answers
Do you have enough balance to send sms.
If yes, the make sure to check the message center number is being used correctly on your phone.
Regards
Anand
Posted on Jul 20, 2009
  • Anand Gupta
    Anand Gupta Jul 20, 2009
    Who is your phone network service provider?
  • Anand Gupta
    Well, then contact Virgin customer care and get the correct mesage center number from them.
    Regards
    Anand
I m sending sms from my sony ericsson xperia X1 but it can't be sent because the pop-up windows appears & shows message sending failed? Is this a softwares problem ?
sounds more like a sms settings problem, try checking the service center number is correct for your sms. or you could contact your network provider and get them to send you the settings for it. hope this helps
Mar 29, 2011 | Sony Ericsson XPERIA X1 Smartphone
I am unable to send SMS with z320i but I can receive SMS
Dear Sir,
Please check your phone message settings.If the message center number is wrong you cannot able to send the SMS.
The center number is different for different Operators.So you may check with your operator to get the message center number.
Once you received the Message center number you can manually input in to your phone by .Go to
Message settings---->message center number--->Input the number and same.
Now you may sent the SMS.
Thank you
Jan 11, 2011 | Sony Ericsson Z320i Cell Phone
I'm unable to send sms to any numbers from my N73. whenever i try to send sms the msg will be held in out box, finally it would say failed. I tryed updating the message centre number but still it is not...
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Dec 29, 2010 | Nokia N73 Cellular Phone
I cant sent messages
hi, try go to your message setting, check if the correct message center number is there. if its not correct or not there, you can not send sms...All you need to do is to call your service provider for the number. .
thanks
Jul 07, 2010 | Nokia 6111 Cellular Phone
My E71 can't send SMS but it can RECEIVE text messages. I have already tried the following: 1. Changed message center number 2. Changed SIM cards 3. Inquired with my network provider. I am enrolled on a...
Try the following steps. I fixed the same problem on my E71 with these.
1. move the sms which can not be sent into the draft box.
2. switch the phone to offline mode.
3. enter draft box, and send the sms
4. after the notification of "saving into sending box..", power off the phone.
5. turn on the phone again, select "no" for the question, then, wait several second, u can see the sms is sent.
Aug 16, 2009 | Nokia E71 Smartphone
Problem in sending sms
if you are unable to send text messages(sms) to anyone then there is a problem with the message centre no. refer your manual to fine the message centre no in your phone(probably in text message settings) and check if its compatible with the service provider.( call the customer care of service provider to get the message centre no) and enter it and save it. then you will able to send text messages.
Jul 02, 2009 | Sony Ericsson T230
Using lg kp500 cookie and i am unable to send sms
Hey check your network ..balance and also important sms message center number confirm that with the original from your network provider and do as per the required
Apr 01, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Unable to send text messages on my new nokia 5800
All you have to do is go to your message setting on your phone:
1. Open Messaging
2. On New message sellect options at bottom
3. Open settings
4. Open Text message, you should see: Message centre, message centre in use ect..
5. Open message centres this should go to next screen then open again, this screen should have : Message centre name & Message centre number (from your network provider you need to find out what is the message centres name & number are e.g in Australia it should be SMSC1 and number is +61411990001) then just manually enter these in there.
Feb 26, 2009 | Nokia 5800 XpressMusic Smartphone
Texts go to outbox but are not sent
Had a similar problem myself (Sony Ericsson W890i) - just a plain old SMS message got 'queued' in the outbox, and all further messages I tried to send got sent to the outbox too without ever being sent.
What I did was delete all the messages that I could from the outbox (5 out of the 6 which had been 'queued'), and the one remaining message that I could not delete I cancelled, sent it to the Drafts folder, and then Saved it (to the SIM). I then switched off the phone, took out the SIM card, put it in my old Sony Ericsson handset, switched that on, went to the Messages folder and deleted this one troublesome SMS message from the 'Saved' sub folder. Replaced the SIM in my current handset, and sending messages thereafter was no problem. Hope it works for you too!
Dec 10, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Nokia 5200 Cellular Phone Logo
187 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
