Question about Miele Novotronic T220 Electric Dryer
My miele T220 has recently started pumping out steam from the circular vent / hole on its lower right side. It didn't used to do this so I 'm wondering why it's started and how to stop it. Not sure if it's still pmping steam out its rear vent as it used to... Thanks
  • 3 Answers
Only 2 things can cause this. The external vent tube is blocked or clogged, not allowing the moist air out of the dryer, or the internal portion of the vent is clogged. The external one can also be caused by the external flapper on the outside of the house.
Posted on Jul 20, 2009
Why is my miele t220 novotronic have a burning smell when working
If lint material has collected around the heating element this will happen. Locate the element and clean out all debris, lint, etc.
Sep 01, 2015 | Miele Novotronic T220 Electric Dryer
How do you change a belt on a Miele Novotronic t220 tumble dryer.
You might want to post this in the dryer section. Have you checked youtube?
Nov 03, 2013 | Miele Novotronic T220 Electric Dryer
How do you remove the top of the Miele T1515 vented dryer?
hi,
on each side of the lid at the front there is a plastic white cover. remove this with your fingers or a small knife. then using a T20 screw driver unscrew each screw a few turns and then push the screw heads in with your finger. do not unscrew the screws too far or remove them.
last push the lid back a few inches and it will lift off. once off you will see the locking clips that you just unscrewed which hold the lid down. when re-fitting the lid do the reverse and just tighten up the screws.
Apr 12, 2010 | Miele Novotronic T220 Electric Dryer
We have a miele dryer T 234 C and a recent has
Hi most likely seals on heat exchanger (condenser unit).
Lock heat exchanger in place.the should no movement at all.if movement you will require a rear seal for heat exchanger.Where heat exchanger seals in condenser box clean with scourer. check bottom of door seal for debris.
Mar 23, 2010 | Miele Novotronic T220 Electric Dryer
MDBH985AWS, I just purchased new-er dishwasher
if you want to see what it looks like you can see a diagram at sears parts direct .com . let me know if this info was helpful
Feb 25, 2010 | Maytag MDBH985AWB / MDBH985AWS 24 in....
Miele T220 Novotronic
Miele is a top notch machine. Try checking your vent hose. It may be blocked in some way.
Jan 28, 2009 | Miele Novotronic T220 Electric Dryer
Miele T220 drum doesn't turn
sounds like belt may be slipping .. check idler pully for tightest against belt .. belt may be streached and need replacing
Oct 14, 2007 | Miele Novotronic T220 Electric Dryer
Miele Novotronic T220 Electric Dryer Logo
153 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
