Question about Microsoft Xbox 360 Console
I am getting an error message E73 on my XBox 360
I am getting an error message E73 and my XBox 360 screen has frozen. I am getting one red light flashing. I have tried switching it off and removing all accessories, but it hasn't made any difference.
  • 60 Answers
There are a lot of diffrent walktroughs on you tube for this problem decide whitch is best for you. or go to www.xbox.com/support/contact
Posted on Jul 20, 2009
Xbox-360 elite lower right hand red flashing led light code error E73
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 17, 2011 | Microsoft Xbox 360 Console
Xbox 360 Console: one red light code E73 appears on screen...
your xbox is going to die..
but there is a way that you can play it.just heat up your xbox for couple of mins.then try again.it works.
every time you see E73 error just do this
for more help email me how to do.
azibajwa@yahoo.com
May 17, 2010 | Microsoft Xbox 360 Console
One red light and a e73 error code??
Hello sir
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
May 15, 2010 | Microsoft Xbox 360 Console
E73
http://www.xbox-360-red-lights.com/solving-xbox-e73-error
Got the Xbox 360 E73 error? Want to get it fixed? Fact is that this problem may be tough to fix, and that's why many people will tell you to send your console over to Microsoft and pay $150. But is it really worth your $150? Is there maybe another way to get it fixed? The Xbox 360 E73 error may be tough to fix, but this doesn't mean that you can't repair it by yourself.
3 ways to fix the Xbox 360 E73 error
1. Restart your console.
2. Unplug all AV cables, and also unplug the power cord from the wall socket. Once that's done, plug them all back in correctly, and put your console back on.
3. Take out the hard drive, and put your console on. If the troubleshooting error has been gone, put your console off, and get the hard drive in again. Than put your console back on.
If these tips didn't fix your Xbox 360 E73 error, you will have to open up your console, and fix the problem from within. You can do this by 2 ways. You either send it over to Microsoft, or you will actually repair the troubleshooter by yourself with a repair guide.
Fix Xbox 360 E73 error by Microsoft or by myself?
So what to choose? Well, if you send your console over to Microsoft, you will have to pay $150 if your warranty has been expired. Also, you will have to wait for 2-6 weeks before you can get back to playing. You'd better want to avoid this... Right?
It can be done way faster and cheaper... If you fix the Xbox 360 E73 problem by yourself, you will be able to get the problem fixed without spending $150. But, you will have to spend a little money on a repair guide, because that's what you will use.
You will use a repair guide, because it gives you step by step instructions that's including photo's and videos, so you will be able to open up your console, and fix the Xbox 360 E73 error very cheap and easily. See it for yourself, visit: Xbox 360 Repairs
Also, when you fix the Xbox 360 E73 error by yourself, you will be able to get it repaired in less than 1 day, or even within 1 hour. It's done before, so why wouldn't you be able to do it either? Want to play your favourite games again, today? Get yourself a repair guide, visit: Fix E73 Error
Apr 13, 2010 | Microsoft Xbox 360 Console
Xbox 360 E73 error. What do I do?
Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
Apr 07, 2010 | Microsoft Xbox 360 Console
Xbox 1 flashing red light and e73 system error
e73 is an input/output error. Hopefully you are still under warranty. Contact Microsoft at Toll free: (800) 4MY-XBOX or (800) 469-9269. If you are outside of your warranty period, I believe they will still repair it for $99
Feb 21, 2010 | Microsoft Xbox 360 Arcade
E73 Error
Error E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
This error is also caused by a cold solder joint under the Southbridge or the Ethernet chip.Can also be one of the solder joints that lead to the GPU.
check if you are getting any flashing red lights on your xbox 360 power up button, if you are not getting any flashing lights the probably you may try unplugging any Ethernet cable attached if you had tried connecting to Xbox Live and at that time you face this error, re-connect and check
If you still get this problem and you see a single flashing red light on your console, please send your console for repair to MS support if it is under warranty
Dec 24, 2009 | Microsoft Xbox 360 Console
My xbox 360 has shown up one red flashing light and E73
HI. This is an Ethernet port issue.
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port. Try using a new Ethernet cord. If the error continues after the new cord is used, contact Microsoft for a repair ticket. the port will need to be replaced. (Internal connection failure)
Possible solder break
Oct 13, 2009 | Microsoft Video Game Consoles & Games
Has one red light on and e73 appears how do I fix
General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port. Try unplugging and re-plugging all your console's cables.
Sep 28, 2009 | Microsoft Xbox 360 Console
Xbox 360 doesnt work because of one red light and message of E73 that they dont know how to fix
not sure if this will help but i found this video showing a fix for that problem
http://www.youtube.com/watch?v=GTBH29CmFHA
there are many more videos there also, good luck to you in fixing your xbox!
May 27, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
243 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
