Question about Sanyo DS31590 31" TV
Television My television will not come back on.
  • 373 Answers
Re: television
Can you go inside the tv and check the fuse? Are you plugged up properly?
Posted on Dec 30, 2007
0 characters
3 Points
Please my tv with on the standby mode when i try to put it back it couldn't the indicator now goes on and off with picture show please help
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
1. Turn off your TV
  • 2. Unplug the television from the electrical outlet. If you're using a surge protector or power strip, disconnect the television from the strip itself. Only by disconnecting the power cord from the outlet can you ensure no power reaches the TV during the power cycle.
  • 3. Leave the television without power for at least 60 seconds. This gives the television enough time for all components to power down during the power cycle
  • 4. Plug the television back into the electrical outlet. If you're using a surge protector or power strip, plug the television directly into the wall outlet instead. The surge protector may otherwise interfere with the power-up cycle, especially if it is old or damaged.
  • 5. Turn on the television. If the blinking standby light continues, you'll need to move on to the factory reset process.
  • 1. Turn on the television.
  • 2. Press and hold either the "Reset" or up arrow button on the remote control.
  • 3. Press and release the "Power" button on the front of the television, while keeping the "Reset" or up arrow button on the remote depressed.
    4. Release the "Reset" or up arrow button.
    5. Allow the television to reset after the "Reset" message appears on the screen.
    6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
    7.Turn off the television and unplug the power cord from the electrical outlet.
    8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
    9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
  • Dec 30, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Sony trinitron 32 inch television model no. KV-32FS13 doesnt have any video nor audio and standby light just blinks about 4 times
    Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check for any loose sodering points at the vertical output section.
    Mar 27, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    1996 sharp tv model # 25H-M60 co-ax pulled out from the circurt board. I removed the back of the tv,and can see the female end is snap off the case that houses the board. Can i solder that back to the...
    That is what the service provider would do if you took the television in to be repaired. The service provider would attempt to solder the rf connector back to the television or solder a new rf connector to the television.
    Mar 29, 2011 | Sharp 19H-M60 TV
    Color recently changed and I cannot get it adjusted properly. Picture goes in and out.
    Please do the following steps:
    2. Please wait approximately 40 seconds for your TV to completely start up.
    3. On the TV remote control, press and hold the UP ARROW button.
    4. While holding the UP ARROW button, press and release the POWER button on the TV set. (The button may be on the front, top or side of the TV.) NOTE: The TV may turn off and then back on.
    5. Release the UP ARROW button.
    If the issue does not resolve, please follow these steps:
    1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
    2. Unplug the television power cord from the electrical outlet.
    3. Let the television remain without power for 60 seconds.
    4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
    Feb 27, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
    2 yr old Samsung Television screen lite blue wiht white lines
    your television is going to need an internal repair. most likely in the power supply of the television. it would be best to unplug the television until it can be repaired. If you would like to repair the television yourself then please use our premium service so an expert can walk you through it. Or you can search for a local repair service using our local repair search engine.
    Jun 28, 2008 | Standard (CRT) Televisions
    T.V. turns itself off
    What make/model is the TV?
    If it's in a cabinet or other enclosure, try taking it out - it may be overheating.
    Apr 05, 2008 | Standard (CRT) Televisions
    Television shut off and will not come one
    you have a the back cover of your tv.look if the fuse is ok,check the regulator.
    Nov 07, 2007 | Sharp 32F-630 32" TV
    Red lines across screen
    it sounds like a b+ cap going bad and is intermittant that feeds the the video drivers on the crt pcb or the crt is shorting. I have seen intermittant shorts in crt before.
    Mar 27, 2006 | Toshiba 32AF41 32" TV
    Sanyo DS31590 31" TV Logo
    21 people viewed this question
    Top Sanyo Standard (CRT) Televisions Experts
    matt martin
    matt martin
    Are you a Sanyo Standard (CRT) Television Expert? Answer questions, earn points and help others
