Question about Intel Motherboard, 945GC, Core 2 Duo, S775, 800MHz, MATX, Max 2GB DDR2, PCIEX16,2PCI,FENET,Vid,Aud,SATA3Gb (BOXD945GCCR)
My motherboard doesn't starts the processor. the motherboard led is glowing but the processor doesn't starts.
Posted on Jul 20, 2010
Check the seating of the cpu
Posted on Jul 20, 2009
After initialing two red leds on control pannel glows
Need to clarify on what was seen as the LED glow, it can be that the power supply is coming ON but the processor refuses to switch on.Need to check on the processor and controller section.
Nov 30, 2011 | Office Equipment & Supplies
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
My pc is not turning on, the internal green led switches on at powering the machine. tuerning the power button the first time initiates the processor fan to run but stops instantly. nothing else happens...
Faulty motherboard or power supply. Best guess is a fault in motherboard causing excess current and it then shuts down. Try unplugging all peripherals except for graphics card, including the drives. If still nothing, try a different graphics card, different power supply. If still nothing, try a different m/board.
May 16, 2010 | ASUS P5PE-VM Motherboard
No display
Maybe the power supply connector connected to your board is not supplying electricity. Try to use other connector or replace the connector.
Mar 02, 2010 | Intel Motherboard
Actually my system is having the problem like motherboard led is glowing powersupply fan processor fan spinning but when we remove memory there is no beeps from the board so what can be the problem please...
The motherboard LED is supposed to glow, indicating that the board is residually powered, after disconnection
of external power and as a warning of this condition so that you will not further disconnect or connect any
peripherals until the charge on the power retention capacitor is properly dissipated.
The Power Supply and Processor Fans should only run while power is applied, and if the Processor fan is always running at a high, possibly noisy, velocity, additional Processor Cooling may be necessary by means of a higher efficiency heat dissipation system.
If you remove memory from the board, the system should not initiate, as memory has little or nothing to do with
the problems you cite, but everything to do with the proper initiation of your system.
Buy a larger Processor Fan Assembly and those symptoms you cite which actually are problems should cure
themselves, while those symptoms you cite which are not problems will still not be problems.
Apr 18, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
Motherboard not starting!
try to set the jumper setting of the cmos battery in *********** board.you set the jumper setting 1 and 2 with in 3 mins.then try to set back the original setting the jumper seting in 2 and 3.
kira_ryuk99@yahoo.com
Jan 11, 2009 | ASUS K8V-MX Motherboard
Intel Motherboard, 945GC, Core 2 Duo, S775, 800MHz, MATX, Max 2GB DDR2, PCIEX16,2PCI,FENET,Vid,Aud,SATA3Gb (BOXD945GCCR) Logo
112 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
