Question about Tomtom Go 920T GPS Receiver
Red X at boot up.
Unable to boot my G920, comes up with a red X and will not go any further. Unable to connect to computer.
After approx 10 day working with TOMTOM, received the following reply:
We do need to inform you that the 920 carries a 1 year warranty from the date of purchase, if purchased brand new. Based on the serial number and your proof of purchase, your device is out of warranty.
"We do need to inform you that we do not do any kind of repairs on out of warranty units. We do not have repair centers to offer you either, as there are none over here in the US/ Canada. We do apologize for the frustration this can cause. To view our warranty policy, you may click on the link below: "
Bottom line. If your unit out of warranty, just throw it out and never buy a TOMTOM again.
Then, kick your self in the *ss for spending so much money on a GPS.
    Brigadier General:
  • 4,090 Answers
I have no idea why anyone would want to buy one either comnsiedring the number of problems seen on here
Posted on Jul 22, 2009
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
Work all days yesterday, this morning went out to van, got to work and it would not move, lights come on flash but will not move
The code 6 failure code is the toggle throttle [engager] isn't in the neutral position when power is applied to the scooter. If the engager doesn't return to the neutral position as soon as you turn the key on the scooter would start to move, that woul
Engager
1. Check connections on red, white and black wires at crimps and soldered joints. (Flash Code
7)
2. Use meter to check for:
- White & Red: 5k1 + 10%
- Red & Black: 2.5k1 (approx.)
- White & Black: 2.5k1 (approx.)
3. With meter between Red & Black, squeeze engager forward. Resistance should go from 2.5k
down to 01 smoothly.
4. With meter between White & Black, squeeze engager reverse. Resistance should go from
2.5k down to 0 1 smoothly.
5. Check voltages (with key on):
- Forward - Red- 4.5V + .1V
- Neutral - Black- 2.5V + 0.1V
- Reverse - White - .5V +.1V
If using a Test Harness - White & Red: 5k, Forward - Red & Brown: 2-5k, Reverse - White &
Brown: 2-5k.
1. Use Red & Brown squeeze engager slowly forward 25 down to 0 slowly.
2. Use White & Brown squeeze engager slowly reverse 25 down to 0 slowly. Make sure dial
speed is set to10.
Jul 25, 2012 | Pride Jazzy Select Gt Scooter
Wont start can see picture tho
One or more drivers may be currupt.
Try booting in safe mode and see if it completes booting, if so go to device manager and look if there is a yellow asstrick or red question mark at any device, if so the driver needs to be reinstalled and the device needs to be enabled.
Shut down and try botting normally, if you still are unable to boot normally, disconnect all usb devices connected to the computer, with the exception of the keyboard and mouse, and see if it boots up normally.
I hope this helps.
Good luck and have a pleasent day.
Jun 22, 2011 | Dell Precision Workstation 670 PC Desktop
Losing connectivity to internet..red light goes on on router
Keep the reset button pressed for 3 minutes.
If you have the CD, try to re-install the same router
If you don't, contact the toll-free # 1-800-2235546
Myself or any other technical support executive will assist you further
Jan 22, 2010 | Belkin (F5D5231-4) Router
I removed some programs that wasn't used and defragmented the computer. A few days later I moved the computer to another room and the unit wouldn't come on. I tryed it in several outlets but still wouldn't...
insure that the power plug in back of your computer is firmly pushed in. if that fails look in back of your computer you will see a little orange or red switch .
it will read 115 when you click it to the side or down it will read 220 or 230. click it to 220 and boot computer. if computer comes on click it back to 115 then reboot . let me know if this resolves the problem. if not i will assist further.
Nov 15, 2009 | Compaq Presario 5000 PC Desktop
When i try to turn the viewsonic on the green power button comes on for approx. 7 seconds then flashes off without any picture appearing on the screen. The red power button does not come back on until i...
This generally means the monitor can not detect a video signal. Have you tried a different monitor? Or try the monitor on a different computer.
If those are not options, check you video card and try to boot Windows in Safe Mode (VGA resolution).
Jules
Jul 24, 2009 | Computers & Internet
My broadbank link flashing red
Hi
Flashing red light means system restarted due to power outage and or system was restarted, Wait for system to boot. The power adapter may not be connected firmly in the power socket or the wire connected at the back of your router may be loose.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 10, 2009 | 2wire 1800HG Router (RG1800HG00)
Dell 610initial start up problem
Hi!
You are unable to enter bios....to select drive c...try to remove the hard drive and install it in the other machine that you have....or just boot your notebook without the Hard disk and see if it makes any difference.....
Can you explain more on...
"The computer trys to start and then just shuts down in approx, 8 seconds."
Nov 13, 2008 | Dell Latitude C610 Notebook
Rca 32 inch tv
your problem is in red video output circuit.
as you are seeing lines with red color
those lines are called retrace lines.
please check
  • supply to red video output ckt.&red video output transistor.
  • loose crt base or crt base connector.
  • componenrs related to red video output section
  • red signal coming to red video output ckt from signal processor.
  • at last but rare cases crt weak.
  • hopr this will help
good luck
Oct 17, 2007 | Televison & Video
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
Tomtom Go 920T GPS Receiver Logo
175 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
