Question about Canon PIXMA MP160 All-In-One InkJet Printer
A string like thing attached to the cartridge of my canon printer was rotten, maybe bitten by a mice or roach, what shall i do?what thing should i replace,thanks.
    President:
  • Canon Master
  • 1,447 Answers
Sensor connection bit a mice or eat repear or re-wearing it
Posted on Sep 06, 2009
It shows this message.."some cartridges
Sound like the cartridge maybe the wrong type or part number, even though they may fit and snap on ok, or they are a bad run off from the production line, if the cartridges can be verified to be 100% good, then I would uninstall the printer from your computer and do a reinstall the drivers to your PC. If it still does the same thing Then your printer would most likely need service, also maybe able to call customer support for more help. Thanks Rick.
Jul 29, 2011 | Canon PIXMA iP1300 Printer
The ink cartridge cannot be recognized ,but the ink cartridge was installed properly .Unfortunately,the ink was flowed out ,please tech me a proper manner to comb this problem as soon as possible
Hi, are you using the original ink cartridge or your ink was modified to CISS before? If you just finished refill your ink and this problem occur - the ink cartridge cannot be recognized, you shall take out both your ink cartridge and try to wipe the whole thing with a clean cloth and then carefully put in back. Hope it helps you. Good luck =)
May 22, 2011 | Canon PIXMA MP150 All-In-One InkJet...
What and how shall i start my CANON MX328 printer after getting 5200 problem ?
you have to remove the ink cartridges. Using a clean clothe moistened with alcohol,wipe the dirt at the surface contact of the cartridges. This contact is where the terminal inside the printer touches.
post back if this will not help you. I'll provide you with another solution.
Apr 04, 2011 | Canon MX300 Office All-In-One Printer
New Ink Cartridges Installed Printer won't print on paper
try to remove it and attach it again maybe it is loose or not correctly attached
Mar 01, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My canon mp620 is offline. My at&t modem is working and my computer is online - my computer detects the printer but is offline
The users who are experiencing offline errors while using the Canon printers are suggested to check the connections, settings and printer hardware before proceeding any further. The connection to and from the printer shall be verified thoroughly by the users and any anomalies if found shall be fixed then and there. As these errors can also be caused by printer hardware issues, the users are suggested to check with different key components of the printer like the cartridges, feed tray and more and fix any issues if found. Restarting the printer and the computer after following the above mentioned procedure will help in solving and preventing the offline errors with your canon printer.
Jan 12, 2011 | Canon Office Equipment & Supplies
I'm trying to use refilled ink cartridges in my Canon MP530, but I get a V (or U) 130 error message. Any thoughts?
CHECK INK
A.
U130
An ink tank that was once empty is installed.
Replace the ink tank.
Printing under the situation may damage the Print Head.
Canon shall not be liable for any machine malfunction or damage caused
by refilled ink tanks.
If you want to continue printing with the refilled ink tank installed, press
and hold the [Stop/Reset] for at least 5 seconds, and then release it. Using
refilled ink tanks are memorized.
* This operation will release the function for detecting the remaining ink
level
B.
i am not sure but is working on 520
1. print mono or print color for color
2.stop
3.ok
4.on/off
  1. Switch the printer OFF
  2. Press buttons 1 + 2 + 3 and 4 (simultaneously using four fingers)
  3. Keep pressing this four buttons for 10 seconds
  4. Release the On/Off button (number 4) (Keeping pressing the others)
  5. After a few seconds (when the printer go ON) you can release buttons 1, 2, 3
  1. Maybe step "c)" is not needed
  2. This procedure was used when I refilled the Black cartridge - try using the ColorCopy button instead of BlackCopy button (number 1) if you refill Color cartridge.
  3. Maybe there is no need for all the four buttons - you can try 1 + 4, 2 + 4 or 3 + 4. (or 1+2+4, 1+3+4, 2+3+4)
Dec 02, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I OWN A CANON BJ-10sx printer. It works fine.
Please go to www.usa.canon.com
Search for the compatible cartridge for your printer. That particular printer is so old that the cartridge design more than likely changed.
Don
Nov 23, 2009 | Office Equipment & Supplies
We have a Pixma MP160 and an MP150 all-in-one printer. We have been using re-cycled cartridges without any problems. Both our printers have just stopped working with 'cartridges not recognised'. When...
Hi
Maybe try cleaning the contacts in the cartridge head to ensure no ink has attached to the pins. Use a cotton bud or something similar and ensure the printer is turned off.
Remanufactured cartridges can eventually fail so you may have a duff cartridge if the above doesnt work.
Thanks
Taz
Oct 30, 2009 | Office Equipment & Supplies
Help!!!
if that is what happen the string shoul be replace...but next time you should wait until the cartridge of printer place at the right side..
Oct 12, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
E5 Error when I reinstalled new & original cartridges
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
597
Jul 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
24 people viewed this question
old marine
old marine
