t
tammy jones Posted on Nov 24, 2016
Hooking up a se electronics x1 studio bundle microphone we r do we hook it up to interphase or compute
2 Related Answers
Anonymous
  • 23 Answers
  • Posted on Apr 14, 2012
SOURCE: MY SE X1 MICROPHONE HAS LOW INPUT ON MY FOCUSRITE PLATINUM VOICE PRO PREAMP
Have you tried a different pre-amp to narrow down the possible issues on your audio chain? Or ensure your preamp works properly by trying a different mic on it..
Also, if this is a stereo setup, try balanced cables to ensure this isn't a phase issue - which can reduce volume dramatically.
there are some programs out there that can boost audio, but if the mic itself is damaged, then take it to an electronics/mic expert.
Darren Stagg
  • 61 Answers
  • Posted on Jul 23, 2012
SOURCE: microphone will not hook into computer
What is on each end of the microphone cable in its original form? What's the model of microphone? You need a cable that ultimately (probably need an adapter or two) would have the LO-Z (assuming its a low impedence mic) connector for the microphone on one end and the mini phone plug on the other. If the microphone is low impedance, which most good microphones would be, you will need an impedance matching transformer to convert to high impedance which the computer mic input would expect. That would have a 1/4 inch phone plug output which then needs to be brought down in size to fit the computer mic input. A music store would be your best bet for the required pieces.
2answers
Se Electronics X1 USB (plug-and-play) mic not getting regonised by any machine running any OS
Installation instruction are given on X1USB-driver_installation_instructions (seelectronics.com) Did you installed the mic as stated in the manual ? Which version of Windows you are using ?
Just got my sE X1 bundle pack, plugged it in, set the proper settings in preferences and no signal to my Garageband?mac
To connect this mic to your iMac, you will require the following:
  • XLR mic cable
  • Recording interface or Mixer with phantom power
Output sound
I plugged some speakers into the mic itself, that worked for me. But I cant get the sound directly on my computer
When i record vocals there is crackling. but not when i test the signal ?
Hi, you can check the software your using, it might be from it. Too heavy for your system.
System configuration might not to suitable for the recording software your using.
Also t depends on the Sound card your using too.
But first check your system, You can ask any one around that has a studio to give the system configuration for his system.
I think that will help...
Hope that helps...
Thanks for using fixya..
I JUST BOUGHTA BRAND NEW DELL STUDIO 15 LAPTOP AND I JUST BOUGHT A BRAND NEW BLUE BIRD XLR MICROPHONE A A ART PRE AMP AND I HOOKED THE MIC UP TO MY COMPUTER AND IT ISENT WORKING THE COMPUTER IS BRAND NEW...
Sounds Like you need to Navigate to "Sounds" on your control Panel the Check to see if its there. If so Make it default after enabling it. If not got to Troubleshooting and run that it should clear that problem up
1helpful
My se x1 condenser mic has starting to cut out, usually just for a second and it seems to be when louder noise goes through it (though this is not too loud as its not clipping on my mixer or software)
Clipping can occur at any point in the chain of electronics and may NOT show on your mixer.
Also cheeck your phantom power voltage sent to the mic. Some mixers send much lower than the +48 volts and clipping within the mic electronics can happen with these. Check the voltage between either pin 2 or 3 and pin 1 of the XLR. Note that the pin numbering on XLR's is funny... search google for diagram.
I plug my Maxtor 3200 into my laptop that is running windows vista, and it does not show up? What do I do
check the interphase
1)cable
2) the electronic interphase between the hard disk and the outlet firewire or usb port going to the pc
3) if there is no spin up when you connect the drive directly through a sata or ide interphase then the drive has to be sent for data recovery and replacement as certain ata modules may not be working
dr arora
Does the SE Mini use a standard cable or is there a special cable needed for use in an amp or computer?
you'll need an xlr (male) to xlr (female) to use the microphone with 48v phantom power (from a preamp). phantom power dosnt work with an xlr to jack, only both xlr.
Top SE Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a SE Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
