Question about Freezers
I have 15 year old Kenmore upright freezer -- NOT frost-free model. Recently have found ice buildup at top of freezer ---which returned within days of defrosting. Will replacing gasket solve this ? ?
  • manning49 Jul 20, 2009
    So where do I find new gaskets ? ? Can I do it myself or do I need repair service ?
    Sniper:
  • 80 Answers
Depends on what condition it is in in most cases yes as long as the doors and body are in good shape meaning doors not loose and hanging or holes or dings in the body to allow air and moisture to get in
Posted on Jul 20, 2009
Coil in top of freezer and top shelf in freezer have very large buildup of ice, melted it out but it soon froze back over
Good day,
I assume this is a conventional freezer, not a frost free model.
That condition is caused either by a loss of refrigerant or an internal restriction in the sealed system.
Both are, I'm afraid terminal, unless the machine is under 5 years of age, in which case it would be covered by factory warranty.
Sep 05, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Ice build up in the bottom of my upright freezer
If it's a frost free model, it could be caused by a plugged defrost drain. Every time it goes through a defrost cycle the water is supposed to drain into the compressor compartment. You can defrost it by unplugging it for a day or two and then remove the panel covering the evaporator coil. You should be able to see the drain tray under the coil and find out whats blocking it.
Aug 15, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I have a 7 year old Kenmore Upright Refrigerator/Freezer on top. I am losing the temp in the fridge part only. The back up the freezer gets a thick layer of ice buildup and when i remove the back panel the...
After you taken the back panel off and see a lot of ice forming on the coil before you use your hairdryer you should locate the timer and turn the center of the timer manually into defrost cycle. If you can see or hear the ice melting then your problem is the timer defective. Change the timer and that is all. But if it doesn't do anything then you will need a little bit more on electrical knowledge to deal with the rest on defrost temperature control and the element itself. Hope this help, God Bless.
Jul 13, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore freezer upright frost build up on door
first just take it out and clean that one carefully .And then set correctly and observe it,s working condition.then also it's not working means show it to ur near by worker those who repairs it
Jun 20, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Mar 27, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frost buildup in frost free freezer
There is a defroster built into the ice maker to melt the ice a little around the edges before dispensing on most ice makers it may need replacing.
Jul 28, 2008 | Freezers
Freezer frost
An upright freezer that is not frost free will have the coils in the shelves (shelves are non-removeable) and that is where the frost will buildup.  If your model is like this then it will have to be defrosted periodically.  If your not sure then give me the entire model # from the sticker inside the freezer and I will look it up for you.
Oct 16, 2007 | Amana 19.7 cu. ft. / 558 liter Upright...
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Oct 12, 2007 | Maytag Freezer MQU2057
Freezers Logo
181 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
