Question about HP DeskJet F4280 All In One Printer InkJet
To set printer & scanner
Hi! Excuse me for my english. I have next problem. My HP Deskjet F4275 connects with my comp through USB port. When i was at home it worked good, but now I've moved to country-side and can't to put it in work. It is written on the screen '' can't identify the USB connection''. I'd tried several USB ports (comp has several) but all is in vain. Sometimes it suddenly can be identified but it does not screen or print all the same. Now I'm trying to download driver from internet as I have no disc with me. What could be the matter? I'm not a specialist, just a beginner...
  • 1,511 Answers
Hmm, first check if the printer is installed. Uninstall it.
Then download this driver From HP ( According to your OS)
Install it, plug in the printer and let the PC do it for you. Do not plug in and out the device, it makes that device unrecognized, and you have to restart the PC.
Just plug once in any usb port, and then you will be prompted that a new device have been found, follow the instructions then.
If the problem prevails, don't hesitate to reply.
And if the problem is solved, kindly do Rate!
Posted on Jul 20, 2009
Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
Jun 23, 2011 | Office Equipment & Supplies
Tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
on Jan 29, 2010 | Office Equipment & Supplies
I want to install HP deskjet 3940 in my computer
Do the below steps.
1.Connect Printer cable(usb cable)to Computer&Swicth ON the printer.Printer driver cd also put in your cd/vd drive.
2.Start-device&Printers-Add Printer-Add a Local Printer-Select Port as USB001-Next-Have disk-Select yor Cd/dvd drive(Put Printer driver cd in your Cd/dvd drive)-next-next-Finish.
Jun 11, 2011 | HP DeskJet 3940 InkJet Photo Printer
How do I add a printer to my laptop
At this time, a full feature Windows 7 driver solution is not available for your product.Follow these steps to install and configure the driver that is compatible with the product.
Follow these steps to install the compatible driver in Windows 7.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers . The Devices and Printers window opens.
  3. Click Add a printer . The Add Printer window opens.
  4. Click Add a local printer .
  5. Click Use an existing port .
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  7. Under Manufacturer in the Install the printer driver window, click HP .
  8. Under Printers , select the Deskjet 660c and then click Next.
  9. In the message window, click Finished .
  11. close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties . The Printer Properties window opens.
  15. Click OK .And print a Test Page.
Regards,
Riztech
Jun 01, 2010 | HP DeskJet 656c InkJet Printer
Purchased HP 4210 Printer here in Bulgaria. But
Hi
I have put a PDF manual for your printer on my website for you to look at or you can download Hope it will be some help for you.
Click Link = http://www.4all2sell.com/pdf/HP-F4210-F4213-F4224-F4235-F4240-F4272-F4275-F4280-F4283.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 25, 2010 | HP Deskjet F4210 All-In-One InkJet Printer
I need to connect my hp 1115 printer to my windows 7 computer and I don't have disc to install it. Please help!
We can use generic drive of deskjet 550c to install this printer. Just follow the below simple steps to fix the problem.
  8. Under Printers,select HP deskjet 550c and then click Next.
  15. Click OK.
Thanks and Regards,
Rizwan
Feb 01, 2010 | HP PhotoSmart 1115 InkJet Printer
Cant install my hp deskjet 3325 printer to the windows 7
Follow the below steps to install your printer in Windows 7.
  8. Under Printers , select Deskjet 3600 and then click Next .
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4 .
  15. Click OK .
  17. Click Print Test Page .
Regards,
Rizwan
Jan 29, 2010 | HP DeskJet 3325 InkJet Printer
Hp deskjet 9650 not compatible with Vista 64-bit
Hp Deskjet 9650 printer owner, sorry to inform that there is no Microsoft Windows Vista operating system printer driver solution available for your printer. But there is an alternative way to workaround it so that you can do basic printing with your printer.
As a workaround, an alternate printer driver solution included in Microsoft Windows Vista operating system can be used to perform basic printing to the printer. However you might find that some of the product features are no longer available when using this alternate printer driver, but that is your best option right now.
The alternative HP printer driver that will work with your printer is HP Deskjet 9800.
The Next thing you do is: Install the driver for HP deskjet 9800
1. Verify that the Universal Serial Bus (USB) cable is NOT connected to the printer.
2. Click Start , click Settings , and then click Printers .
5. Select the Use an existing port check box.
6. In the Use an existing port drop-down list, select LPT1: (Printer Port) and then click Next .
7. Under Manufacturer on the Install the printer driver dialog box, select HP .
8. Under Printers , select the appropriate alternate driver for the printer (deskjet 9800) and then click Next .
9. In the Printer name text box, type the printer name and then click Next . The printer driver starts to install.
NOTE: The name of the alternate driver displays as the default name. Change this name to the name of the printer, if desired.
10. After the screen stating that the printer was successfully added displays, connect the USB cable / Parallel cable to the printer and to the computer.
11. On the Found New Hardware screen, click Cancel .
12. For USB connected printer, please proceed to step three . For Parallel port connected printer, please proceed to step four .
NOTE: If multiple pop-up windows display, click Cancel on each window.
Next is: Configure the printer
1. In the printer folder, right-click on the name of the printer and then click Properties .
2. Click the Ports tab.
3. Change the port from LPT1 to the newly created USB port, click Apply .
Last step: Print a test page
1. Click the General tab.
2. Click Print Test Page .
Good luck Cheers!!!
Apr 26, 2009 | HP DESKJET PRINTER, HP OR COMPATIBLE
The scanner wouldn't work on a HP L7680 All In One Printer. I downloaded the newest Hp drivers. The scanner started working, but then I couldn't print from Quickbooks(bookkeeping). I uninstalled the...
Hi ,
go to printers in the control pannel.
click on add a printer
in the wizard click on local printer but un check search for the connected printer, under ports check the usb virtual port on which the printer is connected .. under drivers choose HP as manifacturer and under drivers use DESKJET 550C in case of windows XP or DESKJET 990C in case of vista operating system .. try to print is should print .. issue resolved on near about 100 cases
wishing u good luck
Mar 08, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Desjet 3745 on windows vista
Go to hp web site and download Vista driver package to suit
Oct 20, 2007 | HP DeskJet 3745 Printer
HP DeskJet F4280 All In One Printer InkJet Logo
79 people viewed this question
Seeker5211
Seeker5211
