Question about HTC Touch HD Smartphone
Lg arena unable to conect to orange livebox
I press 1 on the live box and then enter the security key on the phone but then is days unable to connect
help!
I am in france trying to connect my macbookair to a french livebox
Yes, you need to press button #1 on the livebox , which will put it into 'accepting new wifi devices' mode. This lasts about 1 hour.Presumably you've entered the wep key from the label on the bottom of the livebox into your macbook? don't forget it's got to be UPPERCASE characters!
Apr 27, 2012 | Apple Computers & Internet
Cannot connect orange live box c908 to my pc. help
You need to connect an ethernet cable from your PC to the livebox. You should have been supplied a grey cable with red ends. This goes into the red socket on the live box and the network port on your PC.
May 11, 2009 | Computers & Internet
I cant get my I Pod Touch to connect to my Livebox. I have put in every password I can think of including the 26 digit Livebox one - any ideas. It is so frustrating to have been given my I Pod as a...
You need to out the Livebox into pairing mode to allow the iPod Touch to connect.
Press the button marked '1' on the back of the Livebox. This will start the wireless LED flashing and puts the Livebox into 'Pairing' mode.
Use the WEP key that is printed on the label on the bottom of the Livebox.
NOTE: There is a limit to the number of devices you can connect.(6)
Apr 13, 2009 | Apple Computers & Internet
X box 360 wont connect to orange livebox!!!
there could be a problem with the xbox wireless adpter which it maybe a fautly item
Feb 18, 2009 | Microsoft Xbox 360 Console
I can't get the Archos 605 to connect to the internet
I think you have to press the PAIRING button on the back of the Livebox for it to connect !
Jun 30, 2008 | Archos 605 WiFi Digital Media Player
Belkin wireless adapter g usb
WPA is safer as all in all it's a lot harder to crack due to being a lot more characters in the passkey. The easiest thing to do would be explain how i have mine set up. And you could compare the 2.. As i have XP Desktop & Vista aswell. So your Laptop connects ok now but is still an unsecure network.. On your Dektop. When you try to connect. Are you entering the 26 character key on the bottom of the livebox?
The main thing to realise with the Livebox is everything is reversible.. And to not worry about changing something..
So let's get this started, When you open up the " Connect To A Network " you can see your Livebox-XXXX. Next to that does it say "Unsecured Connection"? If this is the case then your Livebox is still not properly configured.. What i would recommend doing is starting a fresh with the Livebox, and i explain how to set it all up from Default. icon_smile.gif
IF you don't remember your internet login details then go to "Configuration.adsl" and click My Services then Internet. Your info will be in there. Hopefully you remember your password.. icon_smile.gif
If you don't know how to do a reset of your liveox. Press and hold the "1" button on the back of your livebox. Unplug it from the mains whilst still holding the "1" for 10 seconds. Then plug it back in. [ still holding the "1" ] The lights will flash a bit and after a minute or two it will go back to normal.
Go back to "configuration.adsl"
Username: Admin
Password: Password
If i start from the top section and work down it should make it easier to follow:
My Services>Internet>Connection Parameters Filled In..
Phone Over ADSL> Nothing needs changing
Digital TV> Nothing Needs Changing.
Liveprinter> Nothing Needs Changing.
Submit
Security> Associated Devices> Will Be Empty
Firewall> Medium
Wireless Connection> Channel Number> 11
Security Key(WPA-TKIP)> Same As What's On Bottom Of Livebox.
Enable Wireless Lan> Ticked.
Submit
Configuration> Update> v5.10.7-uk
Administrator> Change the password while you're there..
Submit
Advanced> Wireless> Pairing Time> 10 minutes should be fine.
Your Livebox name can be left as it is.
WPA Security Only
Wi-Fi Easy Pairing.. Might aswell leave it on..
Submit
Now if we set up your laptop first.
Go into Connect To A Network. Your Livebox should be there. It also SHOULD say Secured Network. If there is a Red Cross then you will need to do what i suggested yesterday on my previous post.
Go back to connect.. Enter the 26 char. passkey with caps lock on.. And you should be connected no problem.
Now for the Desktop.
when you log on.. In the taskbar in the bottom right should be something to do with wireless networks. Double click this.. If it mentions something about using the software that came with the device.. Then use the software.. If not then windowsXP will show your network. Double click it.. Enter the same 26 character code.. And you SHOULD be connected.
Let me know if that works.. Sorry for the really long post, but detail is something i do quite well... icon_smile.gif
May 26, 2008 | Computers & Internet
Nintendo wii
do everything you did before but just before you click ok for the 'test connection' on the wii console go to the livebox and press the 'number 1 button'.now click ok to test connection on wii.provided the 26 digit number is correct you should now get connected
May 25, 2008 | Nintendo Wii Console
Connecting ipod touch
Press pairing 1 button on the back of the livebox and then type in security code make sure that you type in each character in capital letters as the code it is case sensitive (don't set caps lock) for each character use the shift key - You will now be connected to the livebox.
Jan 15, 2008 | Audio Players & Recorders
HTC Touch HD Smartphone Logo
104 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
