Your chair will not stay pumped up its due to the hydraulic pump thats in the chair all you have to do is find out the length of the hydraulic pump go online and Google hydraulic pump replacement and buy it from them
To lower the back, lift it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over. (This definitely applies to Tempur-Pedic TP4100 Office chair.)
Bolts commonly loosen up on these. You may be able to tighten them. I had to turn the chair over, pull out some of the staples that hold the material on and find the nut that went on the inside, then I was able to tighten the bolt again and staple the material back in place. I also had to make a new plastic cross bar for the scissor assembly by using a half inch PVC pipe and two flat plugs and two couplings, I then drilled a hole in the center for the screws to go in. Painted the newly made one with black plastic paint from Lowes and it's stronger now then before. If you want parts here is Home Meridian's contact..........
