Question about Frigidaire PLMB209DC Microwave Oven
Sanyo microwave with grill.Will not heat food.grill works.Can it be repaired.out of warranty.
  • mtrok2 May 11, 2010
    check the large diode most likely it is the problem
    Sergeant:
  • 175 Answers
Hi..the reason to this problem is probably due to the
bad ignitor.
check this out..
thank you..
kindly rate my response..
Posted on Jul 20, 2009
2 Suggested Answers
SOURCE: my sanyo microwave grill combo ,microwave wont heat food
I have a Emerson combo. It wont heat
Posted on Mar 12, 2009
Sanyo Microwave/Combi/Grill 900W em-g 47535 on front. Timer works but does not heat up code 1S on display. Any ideas
It hardly matters what code is showing because clearly the appliance is receiving power (timer works) and the internal workings of a microwave oven are potentially very dangerous and only competent people should open them up and fiddle around inside.
Sorry but the fact you need to ask shows you aren't a person competent enough to risk your neck inside a microwave. If it is a basic oven out of warranty it would be cheaper to replace it, if it is under warranty send it back and if it is a premium model it could be worth taking to the repair shop for a repair estimate.
Sep 23, 2016 | Sanyo Microwave Ovens
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
How to use the Tesco mtg06 microwave grill?do not have instruction manual
The oven may be used purely for microwaving or simply as a grill for cooking such things as toast. The radiant or quartz grill may be used in a variety of ways. You can use microwaves that have grill functions to roast foods, for baking purposes or for grilling food such as bacon or sausages on the racks. Some models also allow you to use both the oven and grill together, and you can produce fantastically presented meals by using the grill to brown off your dish after cooking. The grill will often have low, medium and high settings for you to choose from, letting you control how brown your food is. By using a microwave with a grill, you can prepare great meals or snacks in a fraction of the time that it would take if you used a conventional oven and grill. Microwaves are particularly convenient, as you don't have to keep checking on the food or stand over it as it cooks.
Jul 29, 2011 | Sanyo Microwave Ovens
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Sanyo Microwave EM-G4775 - doesn't heat up......
It's probably a loose connection at the magnetron or a bad magnetron.
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Some manufacturers (in the US anyway) will send you the magnetron to do it yourself. If nothing else, you can save about $75US by taking it to the shop yourself.
Apparently you're in the UK, judging by the model number.
You can find Sanyo UK microwave owner's manuals here.
You can find Sanyo UK support, parts and authorized servicers here.
Oct 12, 2008 | Magic Chef CMV1000B Microwave Oven
Sanyo microwave
Could be the Magnatron, Diode, HV Cap or Transfomer, some also have a high voltage fuse that blow. Unless you really are confident playing with Very High Voltages, and have a meter capable of 5000v, I dont recommend you repair yourself as a microwave will happily electrocute you. Also if the discharge resistor has burnt out on the cap (assuming it was fitted on your model) the capacitor can store enough power to kill you even when the unit is unplugged so you must discharge the cap before playing with anything else to be safe.
Mar 14, 2008 | Sanyo EM-Z2100GS Microwave Oven
Sanyo microwave EM-X515G
I'm thinking that the circuit board has a problem. I doubt it will work but disconnect all the connectors on the board...with the power off and reconnect. It may clean off some goo. If not, use your method as long as it will work and then consider a new board.
Dec 15, 2007 | Sanyo EM-S5002W Microwave Oven
Frigidaire PLMB209DC Microwave Oven Logo
150 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
