Question about Bosch Refrigerators
Bosch KGU31124GB keeps making solid ice where drainage hole is
ive got a bosch KGU31124GB, with a "Ventilation Power System" which keeps making really solid ice where the drainage hole is, this only started in june, when it got hot in the UK, its really solid and hard to get to remove, the only way is to get a spachula and crack it off with brute force, and sometimes theres a flood where the draws are
  • 17 Answers
SOURCE: Drain hole in top fridge section flooding and icing up under vegtable storage draws.
maybe you fridge is tilting to far forward some times a fridge needs to lean back slightly only by 5 degs so adjust the foot t the front. this will mke the water flow towards the back and also help keep the doors sealed better
Posted on Dec 10, 2007
  • 1122 Answers
SOURCE: Remove drip tray from bosch KTR1670GB
YOU MIGHT TRY TO UNCLIP THE COMPRESSOR AND MOVE IT OUT SLOWLY AS HOT TO KINK THE COPPER TUBING,ALSO MAKE SURE YOU USE CLAUK UNDER THE DRAIN PAN SO IT DOES NOT LEAK,HOPE THIS HELP,THANKS-MIKE
Posted on Jun 01, 2008
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
Maytag317
  • 1136 Answers
SOURCE: Defrosting problems
Hi, Can you get me model # so I can assist you further?
Are you getting ice or frost in the freezer?
I can help
Vic
Posted on May 27, 2009
  • 19 Answers
SOURCE: bosch fridge freezer - ice build up and water leak from freezer
could be an air leak around the door seals. put a piece of paper between the door and the freezer if it slides around easly then the seal is leaking air and moisture into the freezer. Also -20 is extream. you could turn the temp up by 10 or 15 degrees and it may solve the problem and so money!
Posted on Jul 26, 2009
I have two Bosch fridges. I just bought this house and there is nothing in either fridge. Worked day we took possession of home, but both stopped working. They have power just won't cool.
Bosch is a high end manufacturer of appliances. Occasionally things can go wrong, such as fluctuations in temperature. Bosch's policy is to charge for calls to customer service advice, even when the appliance is still under warranty, so it's worth trying these troubleshooting steps before making the call. Bosch refrigerators also have an appliance self-test which you can run.
Instructions
    • 1 Check that the plug is inserted into the household power outlet at the wall. If there's no text displayed on the display panel, it is because there is no power to the fridge.
    • 2 Make sure that the door hasn't been left open if the warning signal sounds. The warning signal means the temperature is rising, and frozen food can be at risk. Visually inspect that the ventilation openings aren't covered by household objects, debris or dirt. Press the "Alarm Off" button to switch off the alarm.
  • 3 Ensure that the temperature controls are set correctly if the fridge or freezer compartments get too cold.
  • 4 Check that the water supply is on if the ice-maker isn't producing ice. Test the water supply by using the water dispenser on the door. If "IWD Off" is displayed on the panel, the ice and water are supplies are off and need to be turned on again.
  • 5 Press the "Condensation Heating" switch near the ice dispenser and water outlet on the door if condensation forms on the outside of the refrigerator. If the environment around the refrigerator is too humid, the appliance can compensate for that.
  • 6 Run the self-test program to identify major faults. Switch the refrigerator off and wait five minutes. Switch the refrigerator on again. Press the "Select" and "Options" buttons at the same time for five seconds. The self-test will commence. Keep an eye on the display. "E" indicates a fault which needs reporting to customer service. The number in the US is 1-800-944-2904.
  • http://www.ehow.com/how_5769746_troubleshoot-bosch-refrigerators.html
  • Nov 27, 2014 | Refrigerators
    My Bosch KGU3420GB fridge freezer keeps getting a thick layer of ice in the bottom of the freezer which then 'welds' itself to the bottom freezer draw. Any idea how to fix this?
    Sounds like the drain is blocked and defrost water is collecting in the base. Try a full defrost and check the drain hole clears.
    Apr 23, 2012 | Refrigerators
    Bosch Evolution B20CS50SNS about two years old. No ice is dispensed. Looked inside and tray is frozen over solid. Also looks like water has overflowed and frozen down in bin. Could not figure out how to...
    I've had lots of problems with my Bosch refrigerator ice maker. The ice tray has a tab on the back corner that twists the tray when it cycle to empty the ice. That tab broke off and when I looked into replacing the ice tray the authorized Bosch dealer said the tray is only sold with the complete ice maker unit. Sells for about $160. I have a hard time spending $160 for another complete ice maker when I only need a $10 replacement ice tray. This ice maker is sub-par for an appliance name brand like Bosch.
    Dec 08, 2009 | Bosch Refrigerators
    Hi . My questionis: Ive got a freezer /
    probably defrost problem check for ice behind panel where fan at. defrost t-stat bad is most common
    Oct 27, 2009 | Bosch Refrigerators
    Formation of ice in freezer compartment
    Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
    Water Running in Refrigerator from Freezer
    http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
    heatman101
    Sep 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
    Small puddle of water on floor in front of fridge
    there is a drain pan under the fridge where water is collected then evaporized from the heat of the compressor thet sometimes the pan cracks or the pan is unleveled .check pan
    May 23, 2009 | Bosch Logixx KDR40423 Refrigerator
    I keep getting error message F04 on my BOSCH exxcel 1400 express washing machine. What does this message mean and how can I fix it?
    1. Loose debris blockin pump - Clean drain pump on the bottom of the machine,
    2. Drainage pipe and or drainage hose blocked - I would like help on this as well.
    Mar 01, 2009 | Bosch Washing Machines
    Bosch Running a LONG LONG Time and Watering Remaining
    You could try running the machine with the drain hose leading to a large bucket. If it works OK in this situation then the blockage will be most likely where the drain hose joins the house drainage system - often at a junction under the kitchen sink. With the drain hose disconnected you should be able to see the blockage and clear it with a suitable pointy tool.
    Let me know if this sorts it. Thanks, D.
    Jul 31, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
    Refrigerators Logo
    90 people viewed this question
    Top Bosch Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    jasbo
    jasbo
    Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
