Question about Electrolux Refrigerators
Fridge not cool
I have an electrlux fridge model no: RM 212 its not cooling even thou it is getting hot at the back can you help. Stephen
did you leave the fridge and freezer on for long without anything inside it??? and is it still under garantee
Posted on Jul 20, 2009
Why does my fridge not cool,the fan doesn't kick on and the black little tank gets really hot?
A fridge operates due to adiabatics, which is the ability of a gas to absorb energy by compression, which turns to heat, then dispel heat by evaporation. The little black tank is a compressor which compresses the gas in the condensation loop. When the gas is compressed it heats up, so the little back tank will get hot, as will the condensation grid, often at the back of the fridge, which acts like a radiator to cool down the gas inside. When the gas is evaporated into the evaporation loop, it expands again and any rise in temperature caused by the compression will be lost. Add to this loss in temperature caused by the radiator and you have a total net loss in temperature which is significantly cooler than what you started with.
The problem with your fridge has to start with the fan not working as this fan will help to cool the condenser radiator, unless it is a fan inside the unit itself which just distributes the cool air. (without knowing the make an model of the fridge I cannot determine the reason for the fan). Modern low energy fridges have a better and more economical set-up and it seems that your fridge has seen better days. The compressor is clearly working overtime to get so hot and particularly if it never seems to shut down or the fridge cool down. Sadly, I think it's time for a new fridge. You'll save the money you are currently spending on the electricity to run the old one.
Sep 19, 2015 | Refrigerators
Dometic RM 4224 won't cool on gas or electric. The stack in the back gets super hot, the fridge is not cool at all.
First ensure that the fridge is level. If the fridge is level and still not cooling while there is heat on the rear of the fridge, then you will require a replacement cooling unit. Give Arcticold a call 1-888-782-6665 Web site: ArctiCold Refrigeration We keep it cold
Online Store: http://www.rvfridgerepair.com/
Aug 22, 2013 | Dometic Refrigerators
LG Fridge LSC26945TT compressor getting to hot and not cooling
if it's not cooling unplug it so you don't damage the compressor,hopefully you just have a bad overload and relay,it's plugged into the side of the compressor,with the machine unplugged remove the bottom back panel,look at the compressor,remove the cover on the side of compressor and remove the start device or ptc assy. call your local parts store and give them the model number and buy a new start device for your machine.if you can hear a clicking sound every once and a while and the compressor is hot change this out first,if it still doesn't start then you have a bad compressor and will be in the market for a new fridge if the compressor is running take everything out of the freezer,remove the back inside wall of the freezer and check the evap coil,if the coil is all iced up you have a defrost problem,if the evap coil doesn't have an even frost pattern covering the whole coil you have a freon leak.if you have a freon leak you'll have to replace the fridge..hope this helps
Jul 04, 2012 | LG Refrigerators
My powerpoint fridge freezer model trf 285 ice and frost keeps forming on back wall of fridge even with temp turned up to highest
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost TimerProblem
Water Runningin refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 21, 2011 | Refrigerators
Units runs but cool air will stop even thou blower continues to run after several minutes cool air starts again
Check the theremostat probe to see if it may be too close to the evaporator fins behind filter if touching fins it will feel evaporator being cold before room air and send model number too, Sea Breeze
May 21, 2010 | LG Electronic Window Air Conditioner
Fan not working right very noisey fridge runs all time back of fridge gets hot
replace the fan and it will also cool down the back. the back shoudl be hot somewaht as that is how it cools the inside. its called a heat exchanger. takes the heat from int he fridge to the outside and then the fan cools the coils on the back or underneath the fridge. if the fan is noicy then maybe needs to be cleaned. I foudn that many have dust buildup and that makes it wobble and not cool. Best to repalce the fan 9cheapo to do) and see if that works. Also make sure you vacume the coils in the back of the fridge . They need to have free flowing air to work properly.
Dec 04, 2009 | Televison & Video
Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Jul 06, 2009 | Dometic RM2620 Refrigerator
Inside Not Cooling and Outside is Hot
possibly could ned a new comprossor for the fridge.
Apr 22, 2009 | Haier Refrigerators
RM 2401 1990 Bigfoot RV fridge not cold
you ahould put poop in it it work for me
Jul 24, 2008 | Refrigerators
Refrigerators Logo
172 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
