Question about Jenn-Air W30400P Stainless Steel Electric Single Oven
Jenn Air oven
The oven burns the bottom of foods.
Re: Jenn Air oven
Does anyone know the part number to replace on model W30400P - the digital display is completely out - the oven heats up but can't read time/temp - not a thing on the LED display - thanks!
Posted on Jul 18, 2008
0 characters
3 Points
Some touchpad buttons don't work but some do. Cancel button for bottom oven doesn't work. Have to flip breaker to turn off. CLock works
Jenn-Air WW30430P Oven User Manual - > ... > Jenn-Air Oven
Free kitchen appliance user manuals, instructions, and product support information. Find owners guides and pdf support documentation for blenders, coffee ..
Sep 24, 2015 | Jenn-Air WW30430P Stainless Steel Electric...
Broiler comes on and burns food when oven in bake mode
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
Mar 28, 2011 | Jenn-Air Electric Double Oven
Food burned,oven too hot
This is possibly a problem with the temperature sensor probe (you should check this first as it is the lowest cost). More probably, it is a failure of the control board.
You can have it rebuilt to save some money:
Sep 19, 2010 | Jenn-Air JJW8527C Expressions Collection...
Good morning; We have a new Jenn-Air black glass
Any proprietary glass top cleaner should be suitable. Avoid using a wire based scouring pad but the Scotch type 'plastic/foam' cleaning pads are ok.
Jan 04, 2010 | Jenn-Air Ovens
The bottom "coil" unit in my jenn air over w132 lit up like a firecracker and burned all the way around - and now doesn't work. I replaced it about 2 years ago for the same issue. Is there something bigger...
There are no official problem notices about this so basically no. I have customers that regularly blow heating elements and coils in many other brands and quite a few go every few months.
Nov 07, 2009 | Jenn-Air Ovens
5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
Oven will not heat
Sounds to me like your bottome element is burned out.  I would replace this, or at least take it out and bring it to an appliance store to have it tested.
Mar 04, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Trouble baking
Sounds like it's running too hot. Check temps. May have a stuck relay on board. Run oven and check to see if bake element is cycling off when it reaches temps. It should stop glowing within
15 minutes from start. If it doesn't you need a relay board most likely.
Nov 04, 2007 | Jenn-Air JJW8330D Electric Single Oven
Oven bakes unevenly and burns food
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air W30400P Stainless Steel Electric Single Oven Logo
185 people viewed this question
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
