Thanks a million guys! turned unit off. drained most of water til it stopped coming out on its own. then held down turbo button which seemed to push the rest of the water out of the unit. when i pushed start it went back on!
  • 19,396 Answers
You are welcome!
G.
Posted on Jul 20, 2009
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
I see 88code after what I have to do for working the salt generator
push the down arrow til it beeps then push the up arrow til it beeps. Push the arrow up til you get to the number of hours you want it to run. Push the down button again til it beeps then push the up button again til it beeps. The pump will start running in 3 to 5 minutes
Jun 24, 2009 | Intex Automatic Salt Water System for ...
Everstar portable ac unit displaying error message P1. The unit turned itself off and will not come back on. It had no symptoms of not working well before turning off.
According to my Everstar manual, P-1 is a drainage problem.
EverStar owners manual pg. 16 -
1. Release the drain hose from the ruber clip and pull out the rubber plug, let the drain hose slant down to a water container.
2. Press the TURBO button on the unit control panel for more than 3 seconds and the WATER INDICATOR light begins flashing. It indicates the forced water drainage feature is activated.
3. Waiting until the WATER INDICATOR light stops flashing and there is no water flow.
4. After the water has drained, remember to secure the drain hose and plug in the upright position and clip it to the unit.
The unit will return to normal operation.
....I had to do this and it worked - Good luck!
Mar 25, 2009 | Heating & Cooling
Washer power
Sounds like you have a stuck or shorted keypad. I've seen this a lot on this model. Solution is to replace the keypad. Catriver.
Aug 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Everstar MPM1-10CR-BB6
Press and hold the turbo button while plugging in the unit. The AC will cycle through a few tests and mine showed that it had excess water. I have long vinyl tubing so the unit could drain outside the window but it thought whenever it would start or stop there was excess water (thus stopping the flow). I drained the excess water out of the line and voila
Jul 08, 2008 | Danby DPAC8020 Air Conditioner
Garmin c550 GPS-Won't turn on at all.
push and Hold the power button down while you push reset, keep power button pressed til it boots again. If it does not, and it's in warranty ship it to garmin. If it's out of warranty, have someone open it up and remove the battery for a couple of minutes.
Jun 29, 2008 | Garmin nuvi 350 GPS Receiver
The directions have the steps to take when a "P1" error is flashing.
1) Remove the plug (the upper black plug not the lower) and attach the included drain hose.
2) Put a bucket under the hose.
3) Press the TURBO button for MORE THAN THREE SECONDS. The WATER INDICATOR will begin flashing telling the user that the FORCED WATER DRAINAGE feature is activated. You will even hear a little whirring noise.
4) Wait until the WATER INDICATOR stops flashing and no more water is flowing out of the drainage tube.
5) After the water is finished flowing, make sure that you FASTEN the DRAIN PLUG. Of course, failure to do this will flood the area.
6) The unit should now work.
You can also move the unit somewhere that you can remove the plug and let the water flow freely (you do not need to have it plugged in for this method) and once the water is finished, replace the plug and fire it up. It should then work correctly. It's also mentioned that the water should be drained quite often to prevent corrosion. I do it every few months and of course when winter approaches.
I like this air conditioner and have had really nice luck with it. A little loud but who cares. That's why there are SUBTITLES on the television.
Hope this helped.
RoC
Jun 17, 2008 | Danby DPAC8020 Air Conditioner
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Everstar Portable air
Well, sorry the response is so late but here goes. I just went through the same problem a few days ago. Press and hold the turbo button while plugging in the unit. The AC will cycle through a few tests and mine showed that it had excess water. I have long vinyl tubing so the unit could drain outside the window but it thought whenever it would start or stop there was excess water (thus stopping the flow). I drained the excess water out of the line and voila. I hope this helped you.
Oct 08, 2007 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
