Question about IceBox IBFS1 LCD Television
Icebox model#185001 on off button in front does not light up the one in the back does but the screen is blank
  • 21 Answers
Re: icebox model#185001
Your power supply went bad. Contact for repair.
Posted on Aug 10, 2010
0 characters
3 Points
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
Sep 15, 2014 - Uploaded by
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Flat Panel Televisions
I have sony KDL32CX520 model it happen to turn into blank scrren while watching tv but the sound works?whats the problem??
What do you mean by this blank screen. A screen with back light only? A screen without any back light [dark screen]? Provide more details please. If you wish to get details about these type of faults to Sony LCD TVs, check this link.
Feb 03, 2013 | Sony 32 inch KDL32CX520 Series Full HD...
Blank screen with sound, unresponsive panel buttons
Nothing is forever or for free, suggest you donate it or recycle it.
Dec 03, 2012 | Niko OTP-3211W 32 in. LCD Television
My 42 inch philips (42PFP5532D) has blank screen but blue light to show its on but nothing on screen :(
just let me know if their is a sound when you turn on the tv then the only problem is black screen. if you can get sound tried to press the channel up/down button let see if you can get a channel. if you hear that receive channel that was mean the problem is either the screen back light get busted or the power inverter is defective. hope this can help good luck.
Nov 02, 2012 | Flat Panel Televisions
I have a Westinghouse Beyond Icebox. Normally, it works just great. However, recently it just stopped working. There is a orange light in the back that is steady. It won't turn on at all. Suggestions?
I had the same problem with my FS04 unit (under the cabinet, flip screen). Amber light was on and humming sound comming from speakers. Motherboard had to be repaired by ICEBOX dealer that sold me my unit.
Their website is
Oct 09, 2010 | Flat Panel Televisions
Mine has the same problem, orange LED with humming sound coming from the speakers etc.
Someone brought one to me to look at..same problem. Checked power supply (easy to check, take off bottom cover and measure voltages on connector. standard 5, 3.3, and 12v outputs going to maine board.) Power supply was fine. took out main board and noticed several 100uf,16v caps that seemed to be bloated. replaced them and the unit turns on. Only thing i'm not sure about is the time it takes to initially turn on. when you first turn on main switch in back, the front led flashes green for about a minute then the LCD comes on and says "loading" which takes about 2-3 minutes, then the unit goes into standby mode (red Led) the unit will turn right on and off again quickly as long as the main switch in the back is not turned off and on again. Is it normal for it to intially take so long to boot? I do not know the normal operation as this is the first i attempted to repair.
Jul 03, 2009 | IceBox IBFS1 LCD Television
Swicthed on tv and its a blank it wont switch off.
Can you see the menus on the screen?
Can you hear audio (sound)?
If you can hear sound but no menu we need to check the backlight.
Take a flashlight and shine it on the screen, look very closely at the screen.
Do you see a video image?
Let me know what happens, I can assist further.
Jan 09, 2009 | Samsung Flat Panel Televisions
Icebox repair
Try . Icebox dealer in NJ, when that company was in business.
Aug 26, 2008 | IceBox IBFS1 LCD Television
IceBox IBFS1 LCD Television Logo
81 people viewed this question
Top IceBox Flat Panel Televisions Experts
Jaime Hernandez
Are you an IceBox Flat Panel Television Expert? Answer questions, earn points and help others
