Question about YouTube Videos
My video stop 3 sec & start &stoping
What can i do
  • 76 Answers
Hi
1. Try open it in another window .
2. press pause wait till the video is fully loaded and the press play .
enjoy
Posted on Jul 20, 2009
Reset ecu on Nissan hardbody 2006 model.stoped it at home,now wont start.maybe for second or two.Nats light not working on dash. keys still opening doors,enjin turning,does not start.enjin check light
Give this a try.....Timing is not as critical with this method...no stop watch needed. Just count in your head...one-one thousand, two-one thounsand, etc, or usestop watch. The most critical step is step #3....wait 10 sec, instead of 7.
1. Ignition "ON", count to 3.
2. Depress/Release pedal 5 times...hard and fast.
3. Count to 10 (not 7!) and fully depress pedal
4. Count to 12 (SES should be blinking), release pedal
5. Count to 10, depress pedal
6. Count to 10, release pedal.
7. Turn off ignition, then 81377951893%26mt_id%3D570%26mpre%3Dhttp%253A%252F%252Fwww.ebay.com%252Fitm%252Flike%252F181377951893%26mid%3D446528%26sdc_id%3D%7Bsdc_id%7D&DealName=12v%20Electric%20Push%20To%20Start%20Engine%20Ignition%20Button%20With%20Red%20Led%20Light%20Up&MerchantID=446528&HasLink=yes&category=0&AR=-1&NG=1&GR=1&ND=1&PN=1&RR=-1&ST=&MN=msnFeed&FPT=SDCF&NDS=1&NMS=1&NDP=1&MRS=&PD=0&brnId=2455&lnkId=8070676&Issdt=150102050536&IsFtr=0&IsSmart=0&dlprc=19.99&SKU=181377951893">start engine. Done!
Jan 02, 2015 | Nissan Cars & Trucks
Indesit fridge/freezer starting & stoping
The compressor is supposed to start & stop, it wont run all the time.
Nov 22, 2013 | Amana ABB1927DE Bottom Freezer...
Husqvarna 415 sews few stitches then stops
could be a safety switch problem
try changing the needle
rethread the machine top & bobbin--use every thread guide
clean under the needle plate & in the bobbin area for lint
if the problem persists the machine may need to be checked
Sep 13, 2012 | Husqvarna Freesia 415
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Aug 25, 2011 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
I can not log in my router home page
1. Connect only a comptuer to the router using a ethernet cable to any one of the gray port on the router.
2. In the computer connected to the router, Click on start - > Run / Start scarch -> [type] CMD & hit enter.
3. In the black screen [Command prompt] type Start http://192.168.2.1 & press enter.
4. If still does not work.
5. In the black screen [Command prompt] type ipconfig & check what it the IP address under ethernet adapter local area connection,
6. It should be 192.18.2.x where x is a value from 2 to 254 & the default gateway should be 192.168.2.1.
7. If you get 169.254.xx.xx or any other numbers then try unpluggin the power from the router & pluggin the power back in after 30 sec.
8. Still the same numbers try pushing on the reset button at the rear of the router using a paper clip or pin for 10sec & release it after 10 sec once again unplug the power from the router wait 30 sec & plug back after 30 sec.
9. Again try step 3.
Thanks
Dec 27, 2010 | Computers & Internet
12RES GEN.NAT.GAS FAILS TO START BY STRT BTTN AND TRNSFR SW
If the succession is 3-5 sec crank - 3-10 sec pause, it is OK, but the cranking is not successful (the reason should be investigated).
If the succession is more rapid 1 - 2 sec you may have bad PCB control.
Jun 03, 2010 | Kohler 12 kW Emergency Power System -...
2003 dodge pickup 5.7 hemi motor ---- driving along fine stoped at stop light it started to run rough , then stalled ,it started back up then stalled again . now it will roll over ok but will not...
your problem sounds fuel related chk your fuel pressure. or simply turn key off then to on position (engine off) and see if u can hear your fuel pump run (2-3 sec) then it will turn off.
Nov 07, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Indesit wm12x wont finish cycle just clix through dial,can u help me ?
i suspect that you may not be draining water,if you watch the light flash it will flash at 1 sec interviles it will then stop for approx 3 secs and then start flashing again at 1 sec int,if you wait for it to stop for aprox 3 secs.when it start flashing again count how many flashes til it stops again for the 3 sec,thats is your fault code,if it is 10 or 5,then its will be your pump blocked or inop.
Apr 05, 2009 | Indesit W 123 Front Load Washer
I have Panasonic NN-S262. After i press the buton start it is working for 3-4 sec and stoped.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In most cases, this is a problem with the inverter.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 06, 2008 | Panasonic Microwave Ovens
YouTube Videos Logo
137 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
