Question about Black & Decker Garden
It will not mow in a straight line. - Black & Decker Garden
  • bill
    bill May 11, 2010
    First check all the wheels are nadjusted to the same hight. Your deck could have a dent in it which will move the wheel and axle . If so you can allways bend it back
Was mowing and left side slowed noticeably. Had to pull way back on right side to go straight. What's wrong?
you gave no details on your machine.
Self propelled? If it is a simple manual push machine, I would see if the front tires are loose.
Dec 31, 2015 | Garden
How do I fix a gradual drive power loss?
Check for fuel flow at the carby ,fuel line might be blocked.
Aug 26, 2014 | Garden
The engine stops after I have been mowing for about 15 minutes. I remove the gas line from the tank and blow it out in both directions with my air compressor. Mower then runs fine until the next time I...
sounds like dirty gas tank or fuel clean out tank reel goodistall new fuel line install inline fuel filter and clen out carb after this should be ok to
run
Aug 27, 2013 | Garden
Strong Fuel Odor After mowing
the needle valve in the carb is not seating replace it
May 26, 2012 | Garden
I have a riding mower model # 96040015 02 ser. # 1001094003997 and when the steering tires are straight forward one tire is straight and the other tire is at least 20-30 degrees to the outside....
You have a bent steering rod or misalignment. Either way git down there by the steering wheels and check it out.....You must have hit something in your mowing dreams??????
Apr 19, 2011 | Garden
How do you fix the front wheel alignment on a 48 inch lawn tractor by Craftman. The wheels are turned to the outside. Theres no bent rods or anything. Whenthe wheels go one way in the frony. you mow the...
make sure tie rod between wheels is straight. if bent will cause wheels to turn outward. take tie rod loose at each wheel, straighten rod reinstall wheels should be straight.
Aug 21, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Hope this isn't a double post. Yardman push lawn mower rear bag starts right up and then mows about 6 rows before stopping. I start it again and it mows about a row and stalls. I let it sit for about an...
it sounds like you may have a vapor lock on your fuel tank   there should be a diaphragm on the inside of the fuel cap  that lets air in but not out   it may have an air hole clogged  take the cap apart if you can and clean it real good and put it back together   if that is not it  then the float in your tank may be stuck   or a fuel line filter may be clogged
Nov 07, 2009 | Toro Lawn Mower With Toro Power Tools
The front not straight when driving
Its probably bent or broken one of the tie ends on the steering. Ring your nearest suppier they will pick it up and repair it.
Apr 14, 2009 | Agri-Fab Agri Fab Spreader
Garden Logo
32 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
