SOURCE: canon ir2870 eror code e000007-0000 solution
The code has something to do with the fuser heating element which is not getting the correct temp or the film has shifted to one side and the sensor is not seeing the white square on the film. Take out the fixing assy and check the film. The cleaning roller built up with the toner on the fixing assy can also cause problems.
SOURCE: canon error jam
for this case you must call technician for chek it.
because the technician have to detail to chek it.
- position of paper.
- condition of paper.
SOURCE: eror 1688 col blk
Are you using an aftermarket cartridge or one produced by Canon? I've had both success and failure with aftermarket cartridges. They are cheaper but sometimes that comes with a price: high failure rate. There might by plenty of ink in the cartridge but the chip in the front that the printer reads could have failed even though it's new. Try another black cartridge as a test. Here is a link to a site where this is explained in more detail:
http://www.refreshcartridges.co.uk/igloo/how-to-clear-the-canon-check-ink-1682-and-1688-error-messages/
Testimonial: "There is problem with my printer Canon PIXMA MX397 any time there is always the initial start error 5011 how to fix this problem"
