Question about Samsung YP-U2X Digital Media Player
Won't charge &/or power up
Computer see it, firmware was updated, it even ask to upload songs and took them, so this all appears, but it will not power on or charge up.
  • mbh06 Dec 05, 2007
    I already thought about the hold button, that was not it. Now after opening it to verify the hold botton, the blue lights will come on when the power button is pressed, but still nothing powering up on the display.
  • Lauren2122 Dec 13, 2007
    Actually, I tried to update the software, anything went ok, then
    my YP u2J died. I tried to manually reset it, nothing to do.
    When I plug it into cpter, nothing, when I try to turn it on nothing. I think something burned inside.
  • 52 Answers
You might have one of the two problems:
1. Your file format might be NTFS instead of FAT.
2. The HOLD button is still kept in the on position.
Posted on Dec 05, 2007
It will not turn on or charge
Hi, the Philips GoGear is a portable MP3 player with additional functionality such as the ability to record your voice or the radio. Some minor problems may develop in the device that keep if from working normally. The most common issues are the GoGear freezing, not powering on and memory-error messages. Troubleshoot your device to return your GoGear to normal operation.
1. Your GoGear may not respond to button presses from time to time. This is often caused by an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
GoGear Does Not Power On
2. Problems with powering up the GoGear are often the result of an exhausted battery. If you cannot power on the GoGear, charge the battery with the supplied charger.
In some instances there is an error with the device that is keeping it from powering on. Unlike the errors that freeze the device, errors that keep it from powering on cannot be cleared by pressing the "Reset" button. The errors need to be fixed by using the "Firmware Manager." The Firmware Manager is a computer program that restores your device to their factory conditions. You will be able to use your device again after restoring it to factory conditions, but you will lose all of the data on your GoGear.
To use the Firmware Manager, open the installation CD supplied with your GoGear and follow the onscreen instructions to install the Firmware Manager on your computer. Plug the GoGear into the computer and check that your computer is connected to the Internet. Open "Firmware Manager" on your computer. You will be prompted to "Restore" the firmware or "Update" the firmware. Since you need to restore your device to working order, select the "Restore Firmware" option. Updating the firmware will not delete the files or errors that are causing the GoGear to malfunction.
Once the process is complete and your GoGear can power on again, consider updating the firmware. Updates give your device extra functionality and repair errors in the device.
Hope it helps...
Have a nice day.
Feb 22, 2011 | Philips GOGEAR SA6045 MP3 Player
I dont have sandisk driver for my sansa E260..i cant transfer songs..
Sansa Not Recognized: Try connecting it to the back of your computer or another computer the back straight to the motherboard this should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software ( download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software when finished disconnect.... Sync to upload songs to the sansa......Hope this works
Dec 01, 2010 | SanDisk Sansa e260 MP3 Player
Sansa express player does not respond, looks like it's off (screen is black) but when connecting headphones it makes the sound as if a song is paused, computer can't see it so its impossible to format. ...
Try and do what is called a Power Reset. To power reset the device, simultaneously press and hold the center and volume up button, while connecting it to the PC.
If this fails, charge the device for at least two and a half hours. The computer should not go into sleep or hibernation state while charging.
Then you may want to update the players firmware by downloading and installing the Sansa Firmware Updater.
Jan 30, 2010 | SanDisk Sansa MP3 Player
My sansa sanclip just froze.iit was charging and
You have two Solutions.
Solution 1:
Resetting the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Solution 2:
Updating the Sansa Clip Firmawre:
  1. If it's not installed yet, download and install the Sansa Firmware Updater.
  2. Connect your Sansa Clip to the computer.
3.1. Assuming there's a new firmware available, the following message will appear on your lower right task bar. Click on the balloon message:
3.2. 3b. OPTIONAL: You can also manually run the SansaUpdater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater.
4. Select the Firmware check box.
5. Click Download Now. Firmware downloads and updating starts.
6. Click Finish after the firmware has been downloaded.
7. Disconnect your Sansa Clip from the computer.
8. A "Firmware upgrade in progress" message will appear on the Sansa Clip's display screen. The device will turn itself off after the firmware is updated.
Additional Help:
Sansa Clip Manual Guide.
If you need any Further Help Just don't Hesitate Asking me.
Thank You For Using Fixya.
Good Luck.
Nov 03, 2009 | SanDisk Sansa Clip MP3 Player
My RCA TH11 has stopped working. at first the player would automatically delete songs from the player after i downloaded new songs. i finally got tired of it and erased all the songs so i could start over...
his is a firmware problem. Go to and download (save) the firmware update. Then follow the directions to upload it onto your Pearl. As soon as you are done, it will work perfectly!
I found this on another worked for mine
Apr 25, 2008 | RCA TH1101 MP3 Player
Can no longer connect with computer
possibly needing reset? Try pushing a pin into the reset hole under the back cover.
If that doesn't work, just wait until it runs out of power.
Then charge, and plug back into the computer
Possibly needing to format and reinstall the firmware. The firmware is on the site.
Good luck,
Nov 30, 2007 | Philips PSS110/17 MP3 Player
My yp-k5 wont upload songs?
What you probably need is a firmware update. Many people seem to have this problem and it is fixed when you update the firmware from 1.03 (the one that comes with it) to 1.05 Here's the link to the firmware update:
Aug 25, 2007 | Samsung YP-K5 MP3 Player
Uploading songs
This player is not compatible with iTunes
Ripped from CD - acquire license by going into songs' Properties and clicking on license or digital rights tab; or try and re-sync
There could be something else wrong with player for which the above methods fail. In this casE:
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
-Tha Mp3 Doctor
Aug 19, 2007 | SanDisk Sansa e260 MP3 Player
Western Digital NetCenter crashed
Umm... it sounds bad. If you can't get the unit to power back on after your performed the firmware update, it may have power failed during the update... and "bricked" it. Try a different power source and see if you can get it to at least power up. If it won't, there is probably no way of recovering it. I'd suggest contacting Western Digital to see if they have a recovery process for a firmware failure. Is it still within the warranty period?
Jul 29, 2007 | Western Digital NetCenter WDXE3200JBN 320...
Samsung YP-U2X Digital Media Player Logo
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
