Question about Mitsubishi WT-46809 46" Rear Projection Television
Wharfedale tv code for sky remote
Hi my tv remote is not working so i just want to know the code of the tv to set it on sky remote my tv modle no is 550 ftb
0 characters
1 Points
Does anyone know the code for the Sky Remote Control for Bush A632?
i have the code point remote at tv press tv press red and select till it blinks twice enter code 0145 press tv again then press power then press select to store
May 21, 2010 | Projection Televisions
I have a 30" Targa Visionary TV, model LT 3020. I cannot find a code to make it respond to the latest, rev 9 (or older) Sky Remote.
you will have to ask for the sky operator for the code sir.
mostly there wont be any code. just ask him if you need to change some settings to make it respond.
Aug 02, 2008 | Projection Televisions
Here available codes for Sky Remote: sky remote codes
Nov 05, 2009 | Projection Televisions
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Projection Televisions
I need tv code for samsung le32r51bd. so i can enter it into sky remote control.
Sky HD Code is 1340 to enter it: -
Press TV
Hold down Select and Red Button at same time until Red LED flashes twice
Press 1340
Press Select and the Red LED will flash twice to confirm that it has been set up.
Now press the Power Button to confirm that it operates properly.
May 08, 2009 | Projection Televisions
Can not pair up sky +hd remote to tv for volume control on wharfdale lt32k1cb
I used 0206 for my Wharfedale LT32K1CB which I also purchased from Argos. It works perfect
Feb 26, 2009 | Projection Televisions
Unable to tune my Sky Remote to my tv
panasonic 37in can't pair sky remote with tv
Jan 09, 2009 | Projection Televisions
Code to programme Sky Remote to operate new TV?
i have the same problem with the codes 0035 0125 0049 everything works except turning the volume up. have you found a solution yet???
Dec 31, 2008 | Projection Televisions
The following code: 253 will work on Sky remotes for the following tv:
Bush LT42M1CFA
Bush LT32M1CA
Sep 12, 2008 | Projection Televisions
Mitsubishi WT-46809 46" Rear Projection Television Logo
847 people viewed this question
Top Mitsubishi Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
