Advent 9517 intermittent failier at startup and video problem
When switching on my laptop, sometimes it will boot up into bios and continue to access the hard drive. The next time I boot up the laptop is either dead or the screen does not display a solid image. It has a mutitude of pixelated colours and garbage lettering. This happens often. And sometimes normal picture changes into pixelated after normal start up.
    Master:
  • 404 Answers
Its either a problem with a memory "ram" or the graphic chip. changing the ram would solve it, if not a graphic chip can not be fixed.
Posted on Jul 20, 2009
When I power on my Advent Tacto the Advent logo comes up and then just sits there. I have tried break on power up but that makes no difference.
Removing the hard drive will not boot to the BIOS. Try pressing F2 when your laptop is booting. Change the boot order to your hard drive.
Sep 18, 2016 | Advent Computers & Internet
Does anyone know if an advent 9517 laptop has a built in microphone?
you need a headset to use the microphone port. it is usually pink and headphone port is green
Sep 03, 2014 | Advent Computers & Internet
How to replace the keybord on an advent 9517 laptop
Advent laptops are manufactured by DSG International, which owns the names to other name-brand computers such as Acer and Hewlett-Packard.
The Advent laptop keyboard has integrated mouse touch-pad functions that allow you to move the mouse around the screen with your fingers.
Function keys at the top of the board contain alternate ways to exit and enter software applications.
Function Keys
The Advent laptop keyboards function keys are "hot keys" that act as shortcuts to applications and functions on the computer. The function keys sometimes don't work and won't carry out the function assigned to the key. This problem is considered a hardware malfunction, and the solution is to replace the keyboard or use a universal serial bus (USB) keyboard for the laptop. b> Malfunctioning Keys b> Advent keyboards are made of thin plastic. Striking the keys too hard will cause the keys to break or stick awkwardly in the housing unit that supports the keyboard. When these keys get stuck in the housing unit, a pin tool can easily set the keys back on track. If there are too many keys that get stuck or broken, you can purchase a replacement Advent keyboard and have it installed. b> Mouse Problems b> The mouse is located at the bottom of the Advent keyboard but is connected to the keyboard data strip that sends information through the keyboard unit to move the mouse on the screen. If the mouse malfunctions, check the connector under the keyboard to see if it is loose. A loose connector can cause the mouse or other keys not to function on the laptop. b> Electrical Shortage b> An electrical shortage can cause an Advent keyboard not to work properly. A shortage is when the main board of the laptop is not getting the voltage needed to efficiently operate the computer. When this happens, certain devices underperform or become inoperable. Check to see if your power supply is extremely hot or if your system heats up around the keyboard. If so, replace the electrical adapter. b> Wire Damage From Keystrokes b> The wire that is responsible for the liquid crystal display (LCD) on the Advent laptop extends from under the middle of the keyboard to the LCD display unit. This wire is unprotected and can be damaged from striking the keys over the wire. When this happens, the display will not show the correct colors or the screen will go black. To eliminate this problem, purchase a keyboard cover that fits the keys to relieve the pressure between the keyboard and video cable. b> Keyboard Drivers b> Problems have been reported with upgrades from Windows Vista to Windows 7. Windows 7 will not recognize the system drivers that operate the Advent keyboard. To get the keyboard to work, you must load the old drivers in Windows 7 Safe mode, which is used anytime there is a hardware or software discrepancy. Advent keyboard drivers can be loaded from the original restore CD, which is included with the system at the time of purchase.
http://www.laptopkeyboard.com/Guides.php/Advent/Advent Series/9517 (Black)/KBAD3
Jan 29, 2013 | Computers & Internet
WHAT IS BIOS
BIOS is Basic Input Output System. On startup, before the windows screen comes on, you need to press one of the F# keys to enter the BIOS/setup screen. On my PC I have to press F2 to enter the BIOS/setup screen. The delete key can also take you to this screen on some PC's.
Mar 17, 2012 | Advent Computers & Internet
Hi, I have an advent laptop that only loads to windows when i tap the f8 button. If i switch the laptop on, it stops at the 'advent' logo and won't boot to windows unless i tap the f8 button. Can you...
try adjusting the boot sequence or at least enabling a different priority in the boot sequence ,,press F2 to get to the bios and learn how to navigate these pages
Sep 10, 2010 | Advent Netbook
Advent black screen
This sounds like a bad video driver update.
Restart the machine and repeatedly tap the F8 key. When you see the advanced boot menu appear choose safe mode.
You will see white text on screen that will stop on a system 32 driver, wait a minute and let it boot through.
Next, go do device manager and uninstall the display drivers or roll back the driver to a previous one.
Reboot the machine and it should boot into windows normally. You may have to reinstall the display drivers if they don't reinstall themselves.
Please post back if you need anymore help or advice.
Good luck.
Jun 26, 2010 | Advent Netbook
Laptop needs rebooting
Im using the advent 4211-b and its flawless.small,light ,looks good has all you need built in and also has choice at startup windows or recovery.cant fault it.if you cant reboot.press power ,get as far as you get ,press and hold power button til switch off press power button again to restart(boot)if youre already in windows and cant shut down or reboot do the same.as long as you dont turn off and unplug no damage to the system will occur.
Jan 04, 2009 | Computers & Internet
Laptop advent 9517
Try http://www1.medion.de/downloads/?lang=uk
and also
http://www.ecs.com.tw/ECSWeb/Downloads/Category_Download.aspx?Categoryid=3&MenuID=37&LanID=9
this has most of the advent drivers
Mar 04, 2008 | Toshiba Satellite A135-S2276 Notebook
Video cards
You Can,t really shuffle Graphics cards Around where Laptops Are Concerned.
the individual manufacturers, want you to buy thier Products Only. hence so many different Socet/Board types.
you,ve gotta grin And Bear What you,ve Got unfortunately, check in the Bios settings, how much of your system memory, is designated to running graphics, Can sometimes be allocated More. That you have the latest video drivers installed for your Graphics Card/Chip.
And that you have Sufficient Memory/RAM installed on the laptop.
Alternative, is to sell And Buy upgraded Machine, Alienware recommended.
Mike @ compurepair.
Posted @ 22.01 PM ( G.M.T )
Mar 02, 2008 | Computers & Internet
Computers & Internet Logo
249 people viewed this question
David Payne
David Payne
