Refrigerators Logo
How to replace light bulb on LG GR292QLC - LG Refrigerators
Light inside fridge
unplug from power unscrew the bulb pull the bottom bulb contact out slightly replace the bulb plug in and, test
otherwise replace the bulb
Nov 18, 2013 • Furniture
I replaced bulb on LG tv but replace bulb light is still on
Its the fuse the is located beside the bulb housing. You need to replace this fuse. Its used almost like a timer. The TV detects a new fuse and blows it at this time it resets the bulb life.
2helpful
Can't find light globe in MC924JLA LG Microwave
I think you're referring to the bulb which is not working. You have to remove the cover from the microwave to gain access to the bulb. Replacements can usually be found at appliance repair shops or stores and electrical or lighting supply stores.
7helpful
2answers
We have a Lg LFC25760SW fridge and the lights stay on in side the fridge
LG had a circuit board malfunction with many french door models with fridge lights staying on with the door closed. the bulb lens usually overheats; deforms; and falls off. the plastic frame surround is warped too. the bulb sockets are darkened too. if this is the case, call LG and they will usually repair this overheating issue for free. you can just unscrew the bulbs for the meantime.
4helpful
LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Lg tv will not turn on it is a micro projection 55 inch hd dlp xd hit power a hundred times and it will eventually turn on but this is what it does it will blink yellow the bulb will light up screen will...
Have you actually replaced the lamp first? A weakened lamp will often cause random shutdown or troubles during initial firing of the lamp. The LG televisions will be just the bulb itself not the complete lamp assembly. It's not hard to replace the bulb as long as you first allow the TV to cool down for a minimum of an hour. Then you will want to handle the lamp with latex gloves on to avoid getting oils from your skin on the bulb. You can find your bulb replacement at http://www.partstore.com
3helpful
2answers
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
2helpful
5answers
Lg 52sx4d problem
If the red light scrolls through, you need to replace the bulb. I replaced the my own bulb, and when I tried to turn on the tv the light kept scrolling. What was wrong? I DIDNT FULLY REASSEMBLE THE TV AFTER REPLACING THE BULB.
Make sure that all the screws are put back in and it will probably work if you have replaced the bulb.
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
