I am either in my study or in the living room. This means I am surrounded by computers, TV's, Apple TV, etc... Does this mean all other electronics must be off in order for me to use my headphones?I am either in my study or in the living room. This means I am surrounded by computers, TV's, Apple TV, etc... Does this mean all other electronics must be off in order for me to use my headphones?
I turned off all other devices. The static sound persists. However, it only happens when I turn on my Noise Cancel in the JBL App.I turned off all other devices. The static sound persists. However, it only happens when I turn on my Noise Cancel in the JBL App.
Leave the noise cancel off, it works using what is called white noise. I think that is the static you hear.Leave the noise cancel off, it works using what is called white noise. I think that is the static you hear.
You can't post conmments that contain an email address.
yes but setting it up using wireless headphones would be easier.
3.5mm to RCA Stereo Audio Cable Adapter
Amazon Basics 1-Male to 2-Female RCA Y-Adapter Splitter Cable - 12-Inches
Hey there, the problem with your sony is not a hardware problem, the headphones are completely fine, its the amount of bass you are putting into the headphones, there are two solutions to this, if you're using a mobile device (Apple, android etc...), go to your app store and download an equaliser e.g poweramp, with this, you can adjust the sound going through to your headphones using the built in equalizer (usually 5-10 bands, research this if you have no knowledge of equalisers), you can use this to turn down the bass frequencies in the sound, or the only other thinkable options are if you are already have an equaliser in use, turn it down, because putting all of the bars to the top makes the sound horrible, research on some suggestions for equaliser presets (another word for equalizer settings), or just turn the volume down.
the reason this happens is because bass naturally overpowers treble, and if it is too loud, the treble and mids will be significantly quieter, headphones are a menace for this, so all you have to do is tweak the sound a little (using an equaliser) to find that perfect balance between the different elements of sound.:-) :-)
Windows Vista should see the bluetooth headphones without any extra drivers. If you open your bluetooth options, and you can see the headphones, and it asks for a password, try 0000 or 1111.
Also - check your computer to ensure that it does have bluetooth capability. If the computer doesn't have bluetooth built in, you'll need to use the USB communicator that should have come with the headphones. If you don't have the USB stick that came with the headphones, your best bet is to contact JBL and see if they will send you a new one.
Another thing you can try, just to verify the headphones are good - is to try to sync them with an ipod or iphone and see if you can listen to music through them.
Plug the USB in the front of the xbox360 the USB plugs are shielded in the front that fix your problem it fixed my problem my Dlink wireless router makes it go nuts with that ear piecing popping sound when i plug the usb anywhere else.
Sounds like the cords that are going into the PC/system have static. Remove the cords from the speakers and simply put your finger around the jacks to remove static. Push the cords and the jacks back in and switch on the speakers. Then twist the volume control, turning it up loud and then low, then loud and low again. That should cure the problem as it removes static that gets built up over time. Either that or your speakers could well be damaged.
Contact the company directly and explain your situation, there should be a toll free number for help in the manual or at least an address that you can e-mail or write to.
The most probable cause it broken solder connections on the headphone/ext speaker jacks. If you know someone who can solder fine detail parts...have them try. I dont know what a TV shop would charge but it DOES need fixing
Turn them off and see if the noise goes away.
