Question about HP Officejet 5610 All-In-One InkJet Printer
Can't print it's says the left catridge need to be replace. i already replace a new catridge it still the same the error the left catridge need to be replace. so i ask what is the problem of my printer? my printer is HP 5610 all-in-one
    President:
  • HP Master
  • 1,447 Answers
It is problem your cartridge is demage it is not a original cartridge
Posted on Jul 20, 2009
Carriage slams into left side
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Feb 22, 2013 | Lexmark Z600 InkJet Printer
Print blurring
you have to clean the lsu. laser unit. you will see there is a lot of dust on the bottom mirror inside. it is a big job. advice that you must be tecnical.
Feb 29, 2012 | HP Color LaserJet 2600n Printer
Hi my name is Hector,on my 2.5 inch display it say cartridge erro error #1203. I checked my users guide it dosnt say anything about error numbers.
Error 1203 is a very interesting error code. Here is what I found out about error 1203
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a problem and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
or try this other option:
Dell All-in-One Printer Cartridge Error 1203.
I found if you cover a copper contact on the color cartridge the error clears and the cartridge works. Looking from the contact side for the color cartridge 2nd row contact 2 from the left. I found if I use an ohm meter from 2nd to 3rd contact I measure 119 ohms. I believe that is a shorted cartridge. If you bought it New I would get it replaced. I use a SMALL square piece of Scotch tape. I believe this will work on Lexmark printers.
Jan 06, 2010 | Dell 966 All-In-One InkJet Printer
Still getting Print Cartridge Error after installing new HP cartr
please check the position of the catridges installed. it should be in a correct position. or you might have replaced the catridges in a wrong slot. if it does not work out then either connect your printer to different computer for printing or uninstall the software from your computer, then again reinstall the software.
Oct 29, 2009 | HP Officejet 5510 All-In-One Thermal...
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
Printer MP160 service error 5010 after refill catridge
I had refilled the catrige, then when I start to print a 'service error' window will appear. At the LCD screed shows E.. 4 ..2. I believe the printer simply assume the catridge is depleted, but how can it happened as I already just refilled it.
How to make printer detected the catridge as a full? I really hope you can solve and make my refilling mission succesful and my printer work again.
Aug 13, 2008 | Canon PIXMA MP160 All-In-One Printer
"Insert right cartridge" J5780
u better check the catridges first specially black catridge,or get it tested on any other printer,but before that wipe the back side circuit section of the catridge with a tissue paper,n try,if the catridge is ok then the catride unit is has to be replaced
thnx N
Jan 14, 2008 | HP Officejet J5780 All-In-One InkJet...
Won't recognize cartridge
I belive the catridge sit are dirty,so remove the catridge, find amoist cloth and clean the sits then dry them with adry cloth then replace the catridge.
Sep 25, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
