Question about Whirlpool LER5636P Electric Dryer
Whirlpool dryer (electric) model:LER5620KQ1
Wont do anything except for the element glows when i look inside, dosent turn or anything, the light comes on when the door is open but thats it i did have it on at night fell asleep and in the morning tried to dry another load and it was done and it was still hot inside with the element glowing. i would appreciate any help i can get thanks in advance
  • 1 more comment
  • Anonymous Dec 13, 2008
    Yes I have the same problem,the light in back glows, I unpluged the dryer.
  • bkupferman Jan 14, 2009
    how do I change the belt???
  • mbwarner Jan 24, 2009
    I have the same problem with mine model # LEL8858EQ1 Were is the Thermal Fuse?
Might be a blown thermal fuse in the exhaust channel
Posted on Dec 15, 2007
    Problem Solver:
  • 17 Answers
Do you hear the motor running?? if so your belt broke you will need part # 341241 if you need help changing the belt let me know
Posted on Dec 10, 2007
Dryer will come on but wont start. Sensing light is on
-There are couple things that cause a dryer no to work:
-Thermal fuse, heater element, door switch, start switch.
Good luck
Nov 10, 2013 | Whirlpool Cabrio WED6400SW Electric Dryer
The dryer heats up the first time it starts but wont heat up again i can see the glowing red from the element but the burner wont light
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
Jul 01, 2011 | Whirlpool 78532 Gas Dryer
My Electric Dryer's Heating Element Glows orange while in use
Hi. this is quite normal when you dry heavy items. the dryer has sensors inside the compartment that will sense cotton and wool garment. if needed, the thermal regulator will adjust the element to the appropriate range. If there is a problem, the electronic thermal fuse will blow. this is the safety feature that will trigger itself if a fire or over heating is sensed. Also, if your selector knob is set to a cotton or high heat mode, the element will normally glow intensively during this cycle.
Please rate and god bless.
Mar 19, 2009 | Whirlpool Dryers
Dryer wont come on and light on the inside doesnt come on
this could be that your belt is broken there is a switch when the belt breaks it stop working thanks from gilles
Mar 15, 2009 | Whirlpool LER4634J Electric Dryer
Drum wont turn
yes the start whinding shot,,,replace motor..
Jan 25, 2009 | Whirlpool LER5636P Electric Dryer
alot of dryers have temp overload fuse
Dec 20, 2008 | Whirlpool LGR7646E Dryer
Dryer heating element(s) are inconsistent
there is only 1 element. were you taking these readings with the wires on them?
the other 2 were thermostats.was there lots of lint?
sounds like you may have bad thermostat.
Nov 23, 2008 | Whirlpool GEQ9800P Electric Dryer
Whirlpool Dryer has trouble drying (LER5620KQ1)
Hi rfairess
it sounds like the high limit thermostat is cutting out and not resetting itself.
Sep 16, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer - element heats, then shuts off quickly
Sounds like you have a stopped up vent on your home, when the vent gets stopped up the dryer can't circulate the air properly in the dryer and causes it to get to hot which causes the high limit thermostat to kill power to the element. If you need more help with this visit the link below:
Appliance Repair Guides
Mar 18, 2017 | Whirlpool Dryers
Whirlpool LER5636P Electric Dryer Logo
645 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
