Question about Iomega HDD External Desktop (32660) 80 GB Hard Drive
When i load my external drive onto my computer it pops up but once i try to open it, i get a message saying that i must format it. i triedto do a quik format but i recieve and message saying windows is unable to format. Is it possible to fix the following error witout deleting all the information i have on my drive?
  • 813 Answers
The filesystem on the drive seems to be damaged and it needs to be formatted which means that you shall loose all your data into it. In case you want to retrieve the data then you would have to buy some data recovery software such as Stellar to retrieve the data from it. If you want to format it, then restart the computer in Safe Mode (press and hold the F8 key while starting the windows and select Safe Mode from the list) right click on the drive letter and click on Format, do a full format and not the Quick Format. Do not double click on the drive to try to open it as it might lock the drive and you won't be able to format it. In case your drive doesnot support formatting in Safe Mode, start the computer in Normal Mode and then click on Start >> select Run, type "cmd" without the quotes and press Ok. Command prompt window will open up and in there type "format X:" without the quotes where you need to replace the X: with the drive letter of your USB drive. Make sure that you type in the correct drive letter in the command window, otherwise you might end up in formatting some other drive and loose your other data.
Posted on Jul 20, 2009
Backed up once successfully but any subsequent tries it says 'no space left' on a 320GB Verbatim external hard-drive. Any ideas?
hi
i would format the external dive and then back up the system hard drive on to it. save any necessary data or files onto CD first-- but if you have a back of the hard disk on this external, no need to keep more than one image copy of the computer hard disk drive. i had to format my external. i do not save anything that is of persoanl value on external drive. if i can i save up to 750M of persoanl data on several CDs
please send me 4 thumbs up
Jul 16, 2011 | Verbatim Smartdisk Clon Portable 97061...
My acomdata external is full.....and i can no longer access it....and it wants me to format it....
Do not format it yet.
With the external drive plugged in - go to Computer, and check the little box (or click the external drive icon) and right click on it (if you have to click it to highlight, after the dialogue box open, close it.
Right click on it (with it highlighted) and select Safely Remove
Once you get the message at the bottom right screen that it is safe to remove, pull it out and try using it in a different USB port.
If it still does this, try using it on another computer. If you still cannot access it, try running a defrag and disc cleanup on it, as well as having your anti-virus program scan through it.
I have had this happen once before and received a message as well saying I needed to format it. If I am remembering correclty, these are the steps I took to retrieve my files, and was successful.
If you are not successful in retrieving or accessing the files, you may need to format it - however, try one other alternative.
Try copying or burning the files to a cd/dvd or to your hard drive.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 22, 2010 | Computers & Internet
Friend sent me a usb stick that I can't open
don't format it...most usb sticks actually have two partitions. That partition that is saying to scan or reformat is the partition that has the usb stick setup files. Open the icon "My Computer" and see if there is another drive listed in there....like drive "K" or something else. Usually once you click on not to format, another windown will open and ask what you want to do with this drive. If the other drive is listed, just click on it to open it and retrieve the files. If it isn't listed, try another usb port or reboot the computer and try again and make sure you have an internet connection to see if there is a driver that is needed.
Jun 11, 2010 | Verbatim External, USB 2.0, 750GB...
I have a 500g external simple drive. i am getting a message that i can only read on my mac.
Copy all the data onto your Mac computer.
Take the external drive to a PC computer, and "reformat" it, using "quick format".
Take the external drive back your Mac computer,
and write all the "saved" files onto the drive.
Nov 16, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Running Windows 7 Home premium. External drive Verbatim USB 250 Silver is recognized, but, needs to be reformatted. I've tried to format (NTSF) using tool in Disk Management. Format runs forever and...
Hello and thank you for using Fixya's services.
This problem happens quite a bit with Windows Vista. It seems that Windows Vista puts a hidden file in the backup; which locks the device.
Open the external device (Windows 7 is fine). Click on "view hidden folders and files." Delete any hidden files you may have in the external.
Go back to "my computer" and right click on the external hard drive letter. Choose properties and security tab. Make your user-name as a main user (administrator) and disable the read only.
Reboot the computer and see if this works.
Please let me know if you have any questions.
Nov 04, 2009 | Office Equipment & Supplies
External hard drive problem NEED HELP
Is this a new external with no data on it? If it is, it may need to be formatted.Go to disk management to see if the drive is there. It may need to be initialize first before you can formatted.If it has not been initialized, a message will pop up for you to initialized it. Once it is done, formatted--This should be done only if don't have any data on it.
Good luck
Jul 20, 2009 | Western Digital My Book Essential 500GB...
Reformatting external Hard Drive
click on the hard drive and use the disc manager to format
or right click on the hard drive properties and use the format tab
May 11, 2017 | Maxtor BASICS Personal Storage 3200...
Acomdata external hard drive
No ned to check in that.
The external hard drive can be fomatted by :
Open the my computer, in the my computer or explorer window you should see the drive letter for the external drive.
Right click on the drive you will get the popup menu.
In that select the format option.
But always use NTFS file formatting system.NTFS provides several advantages over FAT32, including support for larger ile sizes.
Use the full format option.
Wait for sometime, until the format is completed.
Then you are good to go.
Good Luck.
Live, Love, Laugh.
May 08, 2008 | Acomdata 250GB External Firewire HD 250 GB...
I am unable to format my Maxtor One Touch III 500gig External Hard Drive. Once i get to 100% using ms disk manager, a message box pops up saying that it was unable to format the hard drive. In linux when i...
If it shows up in windows explorer as a drive, right click it and choose format and choose ntfs as the file format.
Do you know what format it is when you use linux? I dont think you can use a dos command to format an ntfs volume. Your message probably means it cant read FAT or FAT32 because it probably already is NTFS file format.
Mar 22, 2008 | Computers & Internet
Verbatim 120GB external hard drive
goto Control Panel, administrative tools, Computer Management, Disk Management, If it pops up a new disk install wizard follow the directions in it. If not then find the new disk that has no partition on it, right click on that drive to create a partition, then right click on the drive to format it, if it hasent done so already.
Mar 16, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
Iomega HDD External Desktop (32660) 80 GB Hard Drive Logo
83 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
