Question about Hoover Dryers
Hoover dryer lights up element heats but machine wont run keeps saying clean filter ?
  • Hoover Master
  • 5,388 Answers
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Dryer Overheats and or Dryer Gets too Hot
hoover dryer lights up element heats but machine w - 26368069-2c3mgo1ucomcxgarbvmsr4e2-1-0.jpg
26368069-2c3mgo1ucomcxgarbvmsr4e2-1-2.jpg hoover dryer lights up element heats but machine w - 26368069-2c3mgo1ucomcxgarbvmsr4e2-1-5.jpgt/uploads/images/26368069-2c3mgo1ucomcxgarbvmsr4e2-1-5.jpg" alt="2636806hoover dryer lights up element heats but machine w - 26368069-2c3mgo1ucomcxgarbvmsr4e2-1-9.jpg="h_mi" />
Posted on Dec 13, 2016
SOURCE:
yalmer
  • 552 Answers
SOURCE: hoover nextra tumble dryer
Please first check if both fuses or the circuit breaker has not tripped.
If you are getting only 120v on one leg of the 140v power, you may get lights and no heat, otherwise please give the make and model.
Posted on Feb 27, 2008
  • 1073 Answers
SOURCE: Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Posted on Jun 11, 2008
jsrock516
  • 5911 Answers
SOURCE: Dryer Top Hot / New Heating Element Smell
Any time you perform work inside a dryer, lint can get kicked around and settle on components. It is common to have a slight burning smell for a day or so. However, your dryer getting too hot to the touch concerns me. Improper air flow is the number one cause of dryer overheating problems. You may have cleaned the lint out of the interior of your dryer, but did you check the air blower and vent duct lines? In addition, was the heating elements actually bad? Or, did you assume it was bad, because your dryer wasn't drying properly? The following link can explain:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. I would recommend you remove the vent hose from the back of the dryer and attempt to dry another load. If the dryer dries more efficiently and the top panel does not get scorching hot to the touch, then you have a vent clog somewhere EXTERNAL to the dryer. If the dryer air flow exiting the dryer is weak and the dryer still gets too hot to the touch, you have a clog INSIDE the dryer.
Follow these steps, first and see what you find. If you verify your ventilation is clear and not kinked or clogged anywhere, then you might assume you have a component malfunction. I would hope to try to save you from purchasing parts you may not need. I hope you find this information helpful. Let me know if you require additional assistance.
PS Make sure you are using semi-rigid (metal type) vent ducting. It is crush resistant, heat resistant, does not kink easily, and resists rodents. It is what most manufacturers recommend. If you haven't replaced the dryer vent in a while, this may be a good time.
Posted on Nov 18, 2008
SOURCE: Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Posted on Dec 29, 2008
SOURCE: Hoover nextra mega load 7.5kg
On the rear there is a Heating element hidden under the silver cover, on the top of this unit, there is 2 thermostat's, one is a auto-reset set (On the left) around the 100'c mark and one is a single use thermal trip set at 130'c (on the right, also denoted by a blue spot), the idea is when the heater reaches 100'c is powers off until the air temp drops, once it drops the auto-reset kicks in and forses the heater to power back up, however, in the intrests of safety, if the auto reset fails to power down then the 130'c thermostat will permenently remove power from the heater and will illuminate the filter care light, the only way to restore the power to the heater is to either have an engineer replace the whole heater as Hoover/candy do not sell on the thermal cut out to anyone.
you can usually find the heater unit for £30-40, an engineer may charge upto £140 for the same part and fitting.
Posted on Jan 05, 2009
I have a VHV 781NC-80 hoover dryer it's not drying and lights are flashing E15and beeping I've cleaned the filter out please help
The dryer heating element weakens over time and use. Replacements are available and installed by a professional technician. In order be certain of the elements demise, the technician must trace the circuit to be Shure the controller board dose not have a fault contributing to the element not functioning.
With any high voltage parts, to avoid a shock; have a pro inspect the machine.
Jan 15, 2018 | Hoover Dryers
Dryer wont heat
Sounds like your heating element has went out. So you will either have to replace it $100 to $150 or purchase a new one
Nov 30, 2013 | LG Tromm Electric Dryer
HOOVER AUTO DRY 5050ED KEEPS STOPPING
hi there, I have repaired many of these dryers. It will be a faulty heater element, most likely. They cost about $40. If you get a tradesman to fit it, they will prob charge you about $200 all up. Maybe its better to buy a new dryer for around $300? Good luck.
Lance in brisbane.
Jun 17, 2012 | Hoover Dryers
My hoover tumble dryer Hnc175 wont heat up,is still working as normal, just no heat, i have cleaned out the filters and still not working
Heating elements can fail. These are relatively easy and economical to replace. The heating element is not necessarily the culprit if your tumble dryer does not get hot, however. There are thermal overload cutouts fitted to many machines. If they fail, the current will not be passed to the heating element. Replacement is again, fairly straightforward.
Tumble dryers will often have thermostats fitted. A heater control one, and an exhaust thermostat. The first keeps the temperature correct. The second, as its name suggests, monitors the temperature of the exhaust (in case the airflow in the machine is impeded) Once again, replacement is not too much of a problem.
http://www.repairclinic.com/Dryer-Troubleshooting
Please look, at the link above, it will show you how to perform troubleshooting. procedures and repair.
If you feel you don't want to do it yourself, please call a Hoover Tech, and get it looked at. Ask for a "Quote" for the repair, so you get an idea of whats what.
Apr 08, 2010 | Dryers
The machine keeps saying clean out airways yet there is no fluffy stuff on the filters i have hoovered them out as well
Remove all 3 filters, half moon filters below door, filter in door and heat exchanger from front of appliance and rinse under warm water dry and refit.
Nov 17, 2009 | Miele Novotronic T230C Electric Dryer
Dryer only blowing cold air, washing cycle fine.
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor 2 heavy red wires (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element washer motor has heat overload sensor
thumbs up
Aug 17, 2009 | Washing Machines
Hi the my filter light keeps flashing and iv got no heat!
My guess is that the heater element has gone out. There could also be a lint clog in the exhaust vent...it takes air out through the filter...across the heater element....and back through the tumbler to heat the clothes. This is usually what causes heat elements to go out is the excess lint that gets on them and causes them to overheat and burn out!
Dec 14, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Dryers Logo
76 people viewed this question
Top Hoover Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Craig Butler
Craig Butler
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
