Hi, the error E0 is for a paper jam, please make sure your laserjet M1132 paper tray is not to full. You can also do a power reset by..... 1) disconnecting the power cable from the back of the printer........ 2) disconnect the power cable from the wall outlet. 3) Wait up to 10 seconds and reconnect the power cable back to the wall outlet first, followed by the back of the printer. 4) Turn On the printer again.
Connect your printer directly to a wall outlet. (don't use a power hub or a surge protector)
??Here is a screen grab from the manual. If you need the who manual as PDF replay. Or if you have it, please read pages 189-210+.
SOURCE: 60.40 Error Message on HP Laserjet 5025 MFP printer
Hi
Welcome to Fixya
Have alook at the webpage by following this link:
http://servicelineat.ro/hplaserjetm5025.html
Scroll down the page for error listing. Unfortunately error 60.40 is not listed. It may help to ring HP service centre for a full error code list.
Hope this helps. Please don't forget to Rate this solution.
Thank you.
SOURCE: LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
[email protected]
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
SOURCE: SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
SOURCE: I have refilled my HP
I have refilled my HP LaserJet M1132 MFP toner and the print quality does not look good. It is very faint and if I try to increase the contrast, it is not readable. Please advice
SOURCE: Unable to scan on laserjet m1132 MFP
Have you tried START button, ALL PROGRAMS, Windows Fax and Scan?
My ancient HP 3330MFP works fine with it using a USB cable.
