Question about Cuisinart Thermal DGB-600 Grinder
Cuisinart Grind & Brew Thermal Coffeemaker DGB-600
Grinder basket will not come out so that I can clean it!
  • 3 more comments
  • Anonymous Nov 27, 2007
    I have the same problem-grinder basket gerts stuck and really takes considerable (too much) force to remove!!! Any suggestions
  • lkavert Dec 06, 2007
    The manual shows that the basket should come out, but I can't budge it. I'm afraid if I use too much force, it will break. Does the blade come off first?
  • Vicknit Jan 06, 2008
    I can't remove the grinder basket to clean it. I don't want to use too much force to remove it. Is there a trick in removing the basket?
  • Anonymous Jan 22, 2008
    Same problem. The grinder basket comes off 1 out of every 5 times I try to remove it. Very frustrating.
  • Anonymous Mar 15, 2014
    2 probs w/DGB900BC. First-grinder cycles way too long, maybe 4-5 times longer than it should. Have to manually measure beans each use. Second-sensing disk on top of basket sometimes rotates several times after grinding beans. Have to turn grind off and restart, sometimes several times. Chute is clean. Any suggestions? Neither of these problems existed 2 months ago.
  • 5 Answers
I suffered with a stuck grider unti for a long time and just solved the problem..... Remove the filter basket and through the front door look up twords the back left. You can see where the grinder unit sits. There is a slot area where you can stick a screw driver under the grinder unit and pry it up. Do this in a jiggling motion and make sure you are well under the grinding unit, doing so on the edge of the grinder unit underneath will not give you enough suface to work with, in fact you will just bend or crack the edge. Looking in from low on the front (kneeling on floor with unit on counter, worked for me) will let you locate where the screw driver or smal pry tool needs to go. Mine was stuck for a very long time and No amount of pulling or prying from the top would work, I made it pop out in a matter of seconds using this technique from the bottom! Good luck, I'm going to finish my cup of coffee now! :-) Steve
Posted on Aug 02, 2009
I found a real solution after a few attempts. The problem appears to be the brass sleeve inside the grinder shaft or the plastic shaft coming from the coffee maker expanding over time. I re-drilled the brass sleeve and it seems to be working just fine now. No more sticking. It doesn't take much material removal to do the trick, just a few thousandths of an inch.
Posted on Jan 04, 2010
How com cuisinart hasn't found a solution for this...we pay good money for this product an still need a "tool" to take out what should easily come out? I spent money on a new grinder basket thinking it was old and just getting stuck...
Posted on Dec 13, 2009
I am just pulling as hard as I can and the basket does come out. So far I have not broken it.
Posted on Jan 28, 2008
Solution #5 by eclipsh worked really well, I just found a screwdriver head for my cordless drill that was fit into the hole snuggly, then held onto the grinder portion (wearing safety gloves of course) and drilled a bit until it was loose. Don't hit the plastic on the outside, as this is what the machine grabs onto, the metal part is just for placement of the basket.
Posted on Feb 11, 2010
My model DGB 600 has recently started shutting off halfway through a 10 cup brew. It's like the heasting element kicks out on overload. I re-start and it will make it until maybe 1 cup of water left. Anybody else have trouble like this. It's only about 1 year old
Posted on Sep 19, 2009
Had the same problem. Make sure the grinder basket, especially the under side of the basket, is completely dry after cleaning it.
Posted on Jul 04, 2009
Use shorter side of a allen wrench to pry off, quick and ez
Posted on Apr 24, 2009
It should come off very easy. This happened to me and they had me return it for a new one. Now, this just happened again. Very frustrating.
What is stripping the young leaves on my runner beans
This is a problem with your Cuisinart Grind & Brew Coffeemaker? This product uses roasted whole bean coffee. Why in the world would coffee beans have leaves attached? Makes no sense.
Jun 16, 2014 | Cuisinart Thermal DGB-600 Grinder
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Need instructions to operate DGB-600BC
Thanks for the reply. Got rid of the coffee maker. Its a dud. No more information required.
Jun 18, 2009 | Cuisinart Thermal DGB-600 Grinder
Coffee grinder on brew and grind won't work
Make sure the slot between the grind basket and filter basket is clean and free of grounds - then inspect the area near the grinder motor - use the brush that came supplied with the Cuisinart to clean that area out. Once thoroughly cleaned, try one more time to Grind. Let me know if it works.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart Thermal DGB-600 Grinder
I cannot remove the grinder from my cuisinart Grind and Brew Coffeemaker. It still makes great coffee, but I want to clean the grinding mechasim and cannot remove it.
Common with the DGB-600 - you can try icing it down for 10 minutes - once removed, clean exterior with vinegar applied to a rag to get oils off - endemic to this unit - replacing it with exact same model will not help.
Oct 13, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Not grinding beans
-Tha Mp3 Doctor
Sep 01, 2008 | Cuisinart Thermal DGB-600 Grinder
Spring
-Tha Mp3 Doctor
Jul 31, 2008 | Cuisinart Thermal DGB-600 Grinder
Grinder basket removal
Vinegar instead of WD40 - I am pretty sure a good portion of the DGB-600's have this problem, but that is hearsay.
May 31, 2008 | Cuisinart Thermal DGB-600 Grinder
Cuisinart Thermal DGB-600 Grinder Logo
2,446 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
