Ricoh Aficio MP1600SPF Grayscale Copier
Problem for Ricoh Aficio MP1600SPF Grayscale Copier
Jamming
By jim6527 on Jul 20, 2009
paper jamming in machine
Solution #1
posted on Aug 28, 2009
Not Rated)
rrrdddrrrddd
Rank: Wiz
Rating: 88%, 13 votes
1. MAke sure the paper tray end fence is set against the paper.
2. If paper jammed in fuser (accordian shapped) remove the stripper finger that is sticking out by holding and rotating it untill it snaps.
Was this helpful?
Yes
No
Solution #2
posted on Jul 20, 2009
Not Rated)
swan34
Rank: Wiz  Ricoh Expert
Rating: 83%, 453 votes
Hello sir; Go make a copy let paper jam again, do not remove the paper, check the jamming paper area see there have any paper chip stuck in the paper path, clear it, otherwise cleanup roller with alcohal.
Was this helpful?
Yes
No
Popular Solutions for Ricoh Aficio MP1600SPF
Questions and Unsolved Problems for Ricoh Aficio MP1600SPF
Do you recommend Ricoh Aficio MP1600SPF Grayscale Copier?
Answer
Answer
i have model 240 c and i need to find out how to get it to print out stuff from the... (More)
Answer
when sending fax sayw in scree and then when it prints out says jam
Answer
the fax says line error and then prints out jam but there is nothing jammed in there so what or... (More)
Answer
printout shows as a negative ?
Answer
ctengo un problema con mi canon image runner 400s: cloe the lower right cover, el problema es que no... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copiers Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
