SOURCE: how do i change the time on my samsung prostar 816
SOURCE: Samsung Prostar 816
The battery is dead and will not maintain system programing after a power outage. If the battery is not replaced this problem will occur everytime the power goes out.
SOURCE: PROSTAR 816 PLUS
First to change the clock to a 12 hour instead of a 24 hour requires a bit of CAUTION. You have to go into the technician level of programming so be careful. From a display phone, Press #, ( Programming ) is displayed, enter 20, ( MMC Disabled ) is displayed, enter password ( 1 2 3 4 is default ), enter function 4 for 12 hour clock, enter # to exit. If the time and date are displayed wrong you have to go to # 55 and reset time and date.
YY MM DD W HH MM format. W = Day of week with 1=Monday and HH MM must be entered in Military time even though you have a 12 hour clock set. Good Luck
Did you try unplugging power cord for five minutes? often this fix the problem.
SOURCE: How do I increase the hold time (before it starts
To change the hold recall timer on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
press # when finished
