Question about RTO PasLode 900420 Impulse Framing Nailer
I can't put mt paslode finish nailer back together again
I pulled my gun apart to clear a jam and I can't figure how to put back the spring steel coil which keeps the pressure on the strip of nails (it sits inside the slide somehow. It is a straight finish nailer, not that old but I suspect not the current model
  • 2,176 Answers
Go to Paslode.com and you can download a manual that shows the spring. It sits in a recess under the follower that pushes the nails
Posted on Aug 16, 2009
How to put framing gun togther
Posted on Jun 21, 2013
Looking for the nearest repair shop for paslode nail gun in Northren Va
Have all the nails been cleared out of the tool where they were jammed? If not take the fuel cell out of the tool, and remove the battery before working on it. If still persists come back to this website for further help.
Sep 19, 2014 | Omega Paslode 901000 Impulse Cordless...
Have taken gun apart ,and now can remember how it all goes back together , when nailing the thing that slides was jamming , now apart there are 2 pins im not sure where they should be
Go to this site. www.ereplacementparts.com
Look up your gun, they have parts for it there...
They also will have an exploded diagram of your gun so you can see how it goes together.
heatman101
Apr 18, 2011 | RTO PasLode 900420 Impulse Framing Nailer
My paslode angled finishing gun keeps jamming leaving the firing pin in the out position
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Dec 24, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
I have a paslode straight finish nailer, purchased in Australia around 2001. The problem is that the pin that drives the nail out of the gun does not retract back into the cylinder. I have it apart and the...
is the cylinder really dirty, if so it needs a thorough cleaning. your instruction mnual detailes how to do this. also look for a jammed nail in the nose area and possibly a bent driver.
Sep 15, 2010 | Omega Paslode 901000 Impulse Cordless...
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Gun doubles, shoots two nails and jams.
Nails are coated and the coating seems to get inside these machines. It needs to be taken apart and cleaned to work properly again
Jan 16, 2010 | Omega Paslode 901000 Impulse Cordless...
Paslode air nailer
With the Paslode cordless tools there are a couple of things that will prevent the tools from firing; a jam at the nose of the tool, a dirty combustion system and slack in the spring that pushes the finish nails forward.
First, remove the battery to prevent inadvertant firing, then check to see if you've had two finish nails driven thru the head. Remove any finish nails in the tool. Now lift the nose latch up to release the drive head mechanism. Once you have that up, you can look and see if there are any nails jammed in between the guide and the driving ram. You can push up the ram with a flat bladed screwdriver to make it easier to get the jammed nails out.
IF, the jam can't be removed easily with a pair of needle nose pliers, by pulling the nails down and out away from the tool body, you'll have to take the front nose of the tool apart (not normally needed, except in really severe jams).
If the tool isn't jammed, try putting in a new full strip of nails and pull back on the spring about a inch or two and let it go, so it'll push the nail strips all thw way forward, which will make sure the nailer isn't being locked out by the "last nail" safety switch.
Lastly, you need to clean the tool, as they don't work reliably when dirty, so follow the cleaning instructions that Paslode provides with the tool (they're tool involved and lengthy to type here)
Some other things you can check are to make sure the fuel cell cap is properly seated on the fuel cell, by pushing it all way on both sides till it clicks in place. Also, you can check for fuel flow by briefly depressing the fuel cell against a flat surface (no open flames nearby!!) to see if you're getting any fuel squirting out of the cell, as sometimes that helps to get the fuel flowing.
It also needs to be warm enough to operate. These tools don't do well when subjected to very cold temps. I always keep the batteries and fuel cells inside when the temps are below 40 degrees.
I've found that the Paslode finish nailers jam frequently due to the plastic carrier that holds the nails together, so I don't bother trying to use any small nail strips, (2-6 nails left) as they tend to cause problems. It's more productive to just use full to 1/3 strips of nails and avoid the possibility of jamming that comes with trying to load in some 2-6 nail strips.
Hope you find this Very Helpful and best regards!
Aug 24, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
RTO PasLode 900420 Impulse Framing Nailer  Logo
630 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
