Question about Canon PowerShot A710 IS Digital Camera
Battery life When I first had this camera, about 3 years ago, the rechargeable batteries I bought seemed to last for ages. But more recently the "low battery warning" has been coming on very shortly after inserting freshly charged batteries. I have tried using ordinary batteries (high powered) but even with these I can only take a few pictures before the warning light comes on. Once the light is on, the camera goes dead after a few more pictures so it's not giving me a false "low battery" warning in that sense. Clearly the batteries are OK if I am using new ones, unless for some weird reason the camera is draining them super-fast, so what's the problem? Any help would be much appreciated!
  • Canon Master
  • 4,738 Answers
The rechargeables are only meant to last a couple years maximum (pretty good that you got three out of them). Also rechargeable NiMH's have approximately 5 times the power of standard alkaline batteries. Alkaline batteries should only be used in emergencies in digital cameras as they will only last for a short while before they are drained (as you've discovered).
The obvious solution is that it's time to consider purchasing a new set of rechargeable NiMH batteries. Look on the package for a power rating of at least 2,500 mah. Avoid batteries that do not list the power rating as they are generally inferior batteries.
Posted on Jul 21, 2009
    Problem Solver:
  • 5 Answers
I cant take credit for this, I found it elsewhere on another forum, but it sure worked for me. CLEAN the contacts in the battery compartment thoroughly with alcohol, use a *small* bit of WD40 on a ear cleaning bud after that. Do the same to the metal (+ and - contacts) on the battery itself. Things should work fine after that. Did for me.
Anand
Posted on Oct 24, 2009
  • Anand Dhuru
    Anand Dhuru Oct 24, 2009
    Anand
  • 3 Answers
I have the same problem, and I have used different brands, rechargeable non-rechargeable, the new ready to use re-chargeables. Still the low battery light comes on within a shot or 2.
Posted on Oct 16, 2009
Tip
Digital Camera Problem - Shutting Off - Lens Not Retracting ?
If your digital camera shuts off sporadically or begins to malfunction, the fix could be as simple as replacing your batteries!
I was using AA rechargeable batteries when my camera starting acting up. My husband suggested that the batteries might be bad. While they were not new, they had only taken about 20 recharges over the years. I mistakenly thought they'd last for hundreds of charges despite age. As it turns out, rechargeable batteries have a shelf life.
Also, I had been storing my rechargeable batteries in the camera between uses. Remember, it is wise to remove any type of battery from the device if it will not be used for an extended period. This should help to extend the life cycle of your batteries.
Result: Upon installation of new, freshly-charged rechargeable batteries, my camera worked perfectly.
on Jun 19, 2010 | Cameras
I charge my laptop 100% but my battery is low everytime why?
Rechargeable batteries do not last forever.
They only accept about 1,000 charge cycles before becoming a brick.
so if you charged it everyday, that would be less than 3 years.
In addition, as the battery ages, it's ability to fully charge is lessened. That is why it is important to fully discharge the battery before connecting it up again. Some MFRs have software installed to "calibrate" the battery which you should run periodically which will lengthen the life of your battery.
Aug 31, 2012 | HP Compaq Presario V3000T Notebook
I got this camera a few years ago for Christmas and unfortunatley it is the worst camera I've ever had as far as battery life. I can take 2 or 3 pictures and then it shows low battery. I've replaced new...
It seems there is some where inside the camera leakage.. Are you using Li-ion rechargeable batteries or AA batteries For previously cameras, always comes with AA batteries, and most of the battery are with low capacity.
Jan 08, 2011 | Canon PowerShot A540 Digital Camera
Digital video camera DVC-00725F 2 years old I think its the battery- was holding charge for a short time now not at all -
Rechargeable batteries don't last forever, unfortunately. Lithium ones in particular can have their life shortened if you allow them to discharge completely. This camera uses np-60 (Fuji type) batteries. I recently bought a couple of these off Amazon (Polaroid branded!) for less than one pound ($2) each, so there's your solution!
Nov 03, 2010 | Polaroid Cameras
Camera won't turn on using recommended KLIC-8000 battery
It is possible they sold you a faulty battery pack. .
Contact them and explain your problem; they should replace it at no cost to you
-a.
May 13, 2010 | Kodak EasyShare Z712 Digital Camera
I cannot get the LCD view screen to work ?
There should be a menu button on the camera. if there is, go into the settings and turn the LCD Screen back on. (Actually if you press the menu button on the camera, you should see the menu on the LCD screen.) There is an option to turn off the screen to save battery life.
Dec 17, 2008 | Nikon D70s Digital Camera
Short battery using NiMH batteries
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Sep 28, 2008 | Canon PowerShot A85 Digital Camera
Epson 3100 life battery
I have a 3100z and you are right that alkaline batteries do not last long. The thing to do is buy a couple of sets of NiMH rechargable batteries and they last much longer. I,ve just been on holiday and had no problems at all with the batteries. (Although the camera does not give much warning when they need replacing).
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Canon PowerShot A710 IS Digital Camera Logo
510 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
