Where to get replacement for defective remote control?
  • 164 Answers
Buy a universal remote it should work on just about any thing.
Posted on Jul 20, 2009
Remote control not working even though I have inserted new batteries
If known-good batteries were installed, the remote control may be defective. Check for corroded battery contacts.
Dec 20, 2017 | Televison & Video
Tip
HOW TO CHECK A GOOD REMOTE CONTROL Using Camera or Cellphone Camera, use the...
Using Camera or Cellphone Camera, use the camera as your eye point the remote control transmitter to the camera and "on". The light should emit from the remote control. No light means defective remote control. If lights emits in the remote control transmitter replacement of indoor transmitter or main board is recommended. This method is applicable to any Infrared Remote Control.
on Feb 09, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Why did remote control quit working?
Replacement batteries could be defective or installed incorrectly
Oct 18, 2015 | Vizio xrt112 smart tv Remote control for...
The remote control sensor on the TV has stopped working
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Jan 09, 2012 | Televison & Video
It doesn't work
is this a remote to TV or what? I am assuming it's a remote to a TV. If it is not for a TV, let me know, although, the solution is similar to any unit that uses remote control.
There are three possible causes for this problem;
1. Batteries may be dead inside the remote.
2. Remote might be defctive.
3. TV remote sensor/infrared might be defective.
Battries; Simply insert new batteries into the remote and try again. If changing batterises doesn't help, problem as to be from the Remote or TV's infrared.
Yours sincerely
Elect_Comp
May 14, 2011 | Televison & Video
Have new Logitech Harmony 1000 out of warranty installer says may be defective not programmable.
If your remote has been deemed defective by logitech, there is a reasn for this. I would suggest you go back to your point of sale for a replacement. logitechs warranty isnt transferrable between customers. their warrant only covers the first year of use with the remote.
Aug 06, 2009 | Logitech Harmony 1000 LCD Touchscreen...
Our remote control for our tv suddenly stopped working
There are three possible causes; here are the solutions for each:
  1. The batteries are dead. They need to be replaced.
  2. The remote has developed a defect. The remote needs to be replaced with the same one from the manufacture or a suitable Universal remote from your local retailer.
  3. The IR receiver in the TV itself has developed a defect. This would require the TV being repaired by a qualified technician who would purchase the circuit board from a parts distributor. You would be responsible for parts and labor if the TV isn't in warranty.
No, the remote can't be repaired if it's now defective. It can only be replaced.
Feb 03, 2009 | Motorola DRC450 Remote Control
Replace remote control unit model ar-fb2
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
Jan 15, 2009 | Heating & Cooling
Zenith Z25x31d
Hi
maybe you have defective sensor in remote control! or you have defective crystal in remote control! all you have to do is to replace a new one each.
Thanks!
Aug 23, 2008 | Televison & Video
Remote control
First you have confirm what really the defects is, is it the remote control or the control board.
HOW TO CHECK THE DEFECTIVE REMOTE CONTROL:
Check if the remote control if still good, using the camera of your cellphone point remote control to the cellphone camera and press the "on" button of your remote and you can see the light emitting from your remote control transmitter. If the lights emits that means your remote control is good, if not means the remote control is defective. If the remote emits light it means that the receiver at the control board in the indoor unit is defective.
Aug 18, 2008 | Fedders AED24E7F Wall/Window Air...
Televison & Video Logo
Top Televison & Video Experts
