Question about KWorld 1680 TV BOX HIGH-RESOLUTION EXTERNAL LCD TV TUNER (Retail) (KW-TV1680R)
I need to know how i cud use the tv audio of Kworld 1680 TV box when i switch tv option. I cud not hear the audio when i use Antenna
  • 358 Answers
Your Kworld 1680 TV Box should come with a type of cable that is an in-2-in, same type mouth cable, i.e a type of cable that comes with the ear-phones, but this time around, it is the same type of mouth-point that it will have at both ends.
Now Connect the first point to the 'Line-Out' at the back of your TV Box, then locate the 'Line-in' source at the back of your TV, and connect the other end to it.
Actually there are no specific rule to it, infact, if it is not the same type of head that your TV Box, and your TV has, you can easily adjust the mouth type to suite your need, or easily get a Technician to do it for you. What I mean is that, if the Line-In port at the back of your TV is not the same as the Line-Out port at the back of your TV, you can just change the 'Head' (the connector) at both ends to give you what you want.
Now after connecting it, remember to increase the volume of the TV Box also, but not too much because now its going to be amplified by the TV Volume control.
I hope this helps you out, and if it did, please don't forget to cast your votes.
I would like to know if you need more assistance.
Posted on Jul 20, 2009
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
I hooked up the new digital box Comcast sent, but it has no audio. I disconnected the box and tried it by itself and it still has no audio. I went through the menu manually as the remote for the TV does...
I suspect you mean by disconnecting the box and running it by itself you mean you tried to run audio from your TV by itself? Somehow you need to go through the menu on your TV setup to see if the audio output isn't either turned off or muted. THere may also be a switch on the back of your TV near your output jacks which gives a option of Speaker on or off. If the speakers are on and your TV audio works I would suspect a issue with either your patchcords or the Cable Box. I am not familiar with the Comcast Digital Cable box (I have analog). But you may want to refer to the manual or to them to see if something in the menu may turn on audio for that as well.
After doing all that (whew)... and if nothing works you may have a issue with the TV amp. If nothing is hooked up to the tv (as if you were just watching "On Air" with an antenna and no stereo connected can you hear audio?
Let me know.
Kindly, DAVID
Mar 09, 2011 | RCA F27676BC TV
Resolution is out of range.. when i switch on the computer and tried to switch on tv card then " input no support " appears...how can i resolve this
Maybe the resolution you set on the tv tuner is higher than the monitor's resolution, thus the error in displaying the tv. After you turn on the tv tuner, try to change the resolution from the remote control several times, maybe you can find one that your monitor can handle. Good luck!
Dec 09, 2010 | KWorld 1680 TV BOX HIGH-RESOLUTION...
Blue screen has audio can change channels and hear different audio but no picture
Hello
If you can see menu on-screen display, just get into it, surf for blue-back option and turn it OFF first, and see whether there is any grains appears on your screen. If there is no grains, and only a plane raster, your TVs video processor Ic has got damaged, and should need replacement. If there is grains, you just retune it in autotuning option, and allow it to store all the transmitting signals at that time. This process may take two or three minutes to complete, and you should wait till then. Never forget to connect antenna socket to the antenna terminal of your tv.
If you are using set top box, and connected it to the TV through audio-video cable, your TV has no fault, but the set top boxs' video processor has got damaged. OK,
Nov 24, 2010 | Sanyo DS31520 31" TV
No tv picture - only audio - after pc to tv box hook-up
Hi I am a silver surfer but this is how I got it working
First off get the program tou want to watch up on PC Moniter(screen) Then connect 3 cables
Yellow cables / One end to tv other end to yellow hole rear of PC/TV Box
Grey cable small end goes in PC/TV Box just behind the wirds "kworld" other end goes into back of your Computer ,you need to check your Computer manual to see the which one is the connection to your Computer screen(moniter),mine was blue with 2 screws , disconnect this and screw in Grey cable
Black cable narrow flat end into front bottom of Computer ,other end intoPC/TV Box end hole next to yellow cable
Switch on TV and change AV until you see your program, sound will be thu your Computer Speakers NOT your TV
THIS IS FOR A DESKTOP COMPUTER
Jun 15, 2009 | KWorld PC to TV (0872880887527) Video...
Need adator for DTV converter box.
The converter box needs an antenna, but not the one built into the TV. In fact, you should get an antenna designed for the new DTV broadcasts to get the best reception. There are a number of styles and they start at under $10.
To connect the converter box to the TV, you have a couple of options. You can use the channel 3 or 4 output from the box and connect the cable to the TV external antenna jack with the appropriate adapter. Or, since this TV also works as a monitor, you could use the converter box video and audio outputs instead. If the TV has a single A/V input jack instead of separate audio and video jacks (the usual case), Radio Shack and other vendors sell the adapter cable you'll need. One might have been supplied with the TV.
Feb 10, 2009 | Coby Televison & Video
PIP function not working
Hi !
I'll have the same problem, but i solve it when i change the RESOLUTION OF THE COMPUTER of 1680x1050 on 1440x900 at 60hz
TRY IT !
Jan 11, 2008 | KWorld 1680 TV BOX HIGH-RESOLUTION...
KWorld 1680 TV BOX HIGH-RESOLUTION EXTERNAL LCD TV TUNER (Retail) (KW-TV1680R) Logo
42 people viewed this question
Top KWorld Televison & Video Experts
kenwal
Level 1 Expert
Oluwadamilola Adu
Oluwadamilola Adu
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
