Question about Epson TM-U220PD Matrix Printer
Hallo there Am currently using epson u220d and want it to in print in black......not in colour and am using windows xp hp machine.How do i configure it? regards Erastus
    President:
  • 627 Answers
Printer options - printing defaults - settings you have color print mode. Set it ti monchrome
Also at printer properties you have option to set the printer using only black cartridge.
Posted on Jul 20, 2009
Cannot print from command prompt - Epson U220D Windows 7 32-bit New parallel port with driver New centronix to parallel cable Epson driver APD_455dE (I was using Windows 7 64 bit with a...
The Epson works fairly well with XP. It is to be connected to
a parallel port, usually LPT1
using an IEEE certified parallel printer cable. The computer BIOS
setting is best set for standard parallel port, SPP, bi-directional port
or similar. If possible, do not set it to ECP or EPP or ECP & EPP.
The only native driver for the printer is on the Windows CP CD. Install
using the Add Printer wizard.
The Epson LQ-860 drivers, and a few others, can be used. Using these
drivers, you will discover that the printer actually has some resident
fonts (in printer ROM) that are not accessible from the Stylus
driver. However, with this driver, graphics printing quality is
compromised.
Windows 9x drivers _cannot be used_.
Let us know.
Tom
MSMVP
Windows Shell/User
"the_best_of_fools" <thebestoffools@discussions.microsoft.com> wrote in
message news:E7A27E3E-81E7-46CC-B38E-C63AA474A239@microsoft.com...
:I have an Epson stylus color 600 I can't get to work with Windows XP.
This
: printer worked fine with my old Mac.
: I've tried everything I could and nothing is working. The printer is
: connected to
: the computer via parallel LPT1 port. I've installed the WindowsXP
resident
: drivers
: for this printer model (the Epson drivers are too old and not
verified). The
: computer doesn't detect the new hardware with Plug and Play when
turned ON
: (don't know why) so I had to manually Add Hardware (Printer Port) with
the
: Hardware Wizard. I'm not sure how to recognize if the LPT1 port is
active or
: not and set up properly in the BIOS? I read something about having to
set the
: parallel port to ESP or ECP depending on the printer's requirement
(which I
: don't know) in the BIOS?
: Everytime I send a test page or print from a command prompt or WordPad
: nothing happens for 1-2 minutes and then I get a "Printer Out of
Paper"
: message in the pop-up. Of course, the printer has enough paper (and I
can
: print a sefl-test page from the printer). I also tried with another
parallel
: cable and it still doesn't work. I've tried uninstalling/reinstalling
the
: printer's driver many time and it's still not printing.
May 13, 2014 | Epson TM-U220D Matrix Printer
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
What is the baud rate of EPSON TM-U220D MODEL M188D?
hello, make sure there is paper in machine, turn machine off, hold the paper feed button, turn machine on, it will print the configuration of machine. adjust serial port setting on computer for baud rate. to change the baud rate on printer, you will need the user guide.
Sep 28, 2010 | Epson TM U220D Printer
Epson cx3200 wrong colour
It is possible that when the printer senses not enough black ink it will swap to using the colour tanks to try and make a BLACK.
It is also possible that you have mistakenly adjusted a setting in the epson printer program to use the colour tanks to print black and white photographs.
Either of those would certainly cause the problem you describe
Check ALL your printer settings both the windows ones AND your epson ones
If you found this information useful pleas click below
Aug 12, 2009 | Epson Office Equipment & Supplies
Printer not printing as missing ink cartridge - default to black
Hello
Download and install the drivers for it ,the default drivers are for Windows XP if you have Windows Vista then change it on the left column.
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=wsMoc1iChVGcisk9ncQeIBmTUU002FxOg74o84TjGD6F5MAU003D&tc=6#7
Apr 07, 2009 | Epson Stylus D92 InkJet Photo Printer
Epson TM-U220D Receipt Printing Problem
mau download driver epson tm-u220d ga ada...
klo mau cari dimana yah
Oct 21, 2008 | Epson TM-U220 Matrix Printer
Connecting Epson TM U220D printer with Laptop (having Windows XP)
Please verify if you properly install the port converter, its drivers.
Aug 31, 2008 | Epson TM-U220 Matrix Printer
Cant print even test page
hit "start" and go to Printers and Faxes. In the side bar, choose add a printer, follow the instructions in the wizard to automatically, install and use the printer. Also check and make sure that you have any software that comes with the printer, as some of them need it in order to run. If all else fails, uninstall the printer by selecting it in the Printer and Faxes, right clicking and select DELETE. Then follow the above steps to reinstall it.
Jan 18, 2008 | Epson TM-U220D Matrix Printer
Colour???
HP Deskjet 450 and HP Color Inkjet cp1160 and cp1700 Series Printers - How to Print with Black Ink Only Follow the instructions below to print with black ink only.
NOTE: HP Deskjet printers use all the primary colors, Cyan, Magenta, and Yellow, to create shades of gray when Print in Grayscale is selected in the printer driver and the Black only option is not available or not selected.
  1. Click Start , Settings , and then Printers . In Microsoft® Windows XP, click Start and then Printers and Faxes .
  2. Right-click the printer icon and in Windows 95/98/Me, select Properties . In Windows NT 4.0, select Document Defaults . In Windows 2000/XP, select Printing Preferences .
  3. Select the Color tab.
  4. Select Print in Grayscale .
  5. Select Black only .
    NOTE: If the Black only option is not available, download the latest printer driver from the HP Web site. Click here to go to the HP Support and Drivers page.
  6. Click OK to save the changes and close the window.
  7. Print the desired document or graphic.
Oct 25, 2007 | HP DeskJet 450Ci InkJet Printer
Epson TM-U220D Printer Status
Hi, On the PC that will not display printer status correctly, pls run MSCONFIG (start, run, type "msconfig", OK); in the System Configuration Utility Window, click on the tab Startup, see if the EPSON Status Monitor is present and checked. If it is not present, check if you have Lavasoft Ad-Watch or similar program running. This prevents the EPSON Status Monitor from registering and running correctly. If such a program is running, temporarily remove Automatic setting and reinstall the EPSON Status Monitor. Accept any registry modification at this point. Restore all settings once installation is finished. If still a no go, try wiggling the parallel connector a bit and make sure it is snug and fit. If all else fails, you may have to consider: Installing to only 1 PC, share and make it a print server assuming you have networked all your PCs; or re-installing Windows (Ouch!) Hope things work out for you. Pls post again how things turn up. Kind regards.
Jul 30, 2007 | Epson TM-U220D Matrix Printer
Epson TM-U220PD Matrix Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
