How to remove the nc6220 touchpad
How to remove the HP compaq nc6220 touchpad. I followed the guide, step no 4, where is the metal tab ?
3.Press down on the section of the top cover 1 to the left of the metal tab next to the TouchPad .
4.Lift up on the metal tab 2 on the TouchPad until the TouchPad disengages from the top cover.
I also had trouble with this. Go to the section on removing the top cover and remove some of those screws at the bottom near the touchpad, then try lifting on the the metal tab.
Posted on Mar 09, 2011
    Habit-Forming:
  • 62 Answers
Hi...you lock the side please be careful you only go left and upward..good luck and hopefully help me have you..
Posted on Jul 20, 2009
Disc read error
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 12, 2013 | HP Compaq NC6220 Business Notebook
Please tell me master password key for power-on password of hp compaq nc6220.i have already tried to remove bios battery but i can not remove my power-on password
You would have to perform this in the BIOS ( Basic Input/Output System) Here are the steps:
1. Restart your computer. 2. Enter the BIOS by pressing the designated key (usually F1, F2, or Delete key).You will be able to enter the BIOS by pressing any of those keys..(this is the black screen that appears before your window starts up) 3. Inside BIOS, navigate the "menu" option by using the "arrow keys" 4. Search for "user password,system password, or power-on password" as it may vary depending to your system. It should show you "enabled or Active" and you have an option to "disable it" 5. Make the "disable password" press enter. 6. Click the "Save Changes" or "Save Changes and Exit" option in the system and it should not ask you for a password the next time you turn your computer on.
---for your reference, the command help is shown at the bottom of the BIOS screen which will guide you which keys to use while navigating inside it.
Aug 23, 2011 | HP Compaq nc6220 Notebook
Laptop with windows 7, USB mouse stops functioning, build in mouse move any where, but when you click you do not get what you want. any key you press just sound restriction and no result. I cannot access...
Hi
try to get into device manager
scroll down to find touchpad
uninstall it
restart
and hopefully windows will install it correctly when it restarts and finds new hardware
if this dont cure the problem
you could go here
www.hp.com go to support/downloads look for you make and model then look for another
touchpad driver
download it
install it
then restart
hopefully all will be good
good luck
if you do not get sorted please come back to us again
Feb 27, 2011 | HP Compaq nc6220 Notebook
Laptop mouse pad not working+hp compaq nc6220
To fix your touchpad, follow the information from this link.
Jan 25, 2011 | HP Compaq nc6220 Notebook
HP Compaq nc6220 PC Notebook Boot sequence
1) Turn the laptop on
2) AS SOON as you see > F10 = ROM Based Setup, in the lower left corner of your LCD screen, press the F10 key.
3) You will see the headings > Main, Advanced, Security, and Tools.
Use the appropriate Arrow key to highlight Advanced. (Look at the Navigation guide to see the proper key to use)
Press the Enter key.
4) Use the appropriate navigation key to highlight > Boot Order
Press the Enter key
This will show you the Boot Order Sequence.
What you are doing now is just looking around. You haven't changed any settings yet.
If you need to change the Boot Order Sequence, you have to use the appropriate navigation key, and highlight Multiboot, and then press the Enter key. Disable Multiboot.
Save changes.
If you do Not save the changes, it will be like you have done nothing at all.
[The navigation guide shows you the key/s to press to navigate around in BIOS Setup.
You may see,
Page up/Page Down, or -/+
Left Side Arrow key, or Right Side Arrow key.
Enter key ]
If this is not what you had in mind, please post in a Comment.
Nov 25, 2010 | HP Compaq nc6220 Notebook
I have a Compaq Presario CQ60 scroll touchpad stop working
The notebook model you have is shipped with the Synaptics touchpad driver. Please follow the below steps to enable scrolling features:
1. Open Control panel -> click on Mouse . It will display Mouse Properties dialog box.
2. Under Mouse properties Window click the Device Settings tab
3. Click on Device Settings -> Settings button. This will display the Properties for Synaptics TouchPad on PS/2 port.
4. Follow the steps below to enable the Tapping Feature :
Highlight Tapping in the Left hand side , and Check the Enable tapping in the Right hand box .
5. Follow the steps below to enable Scroll feature:
Highlight Virtual Scrolling in the Left hand side and Check both the boxes in the right hand side.
6. Click OK .
Alternatively you can anble scrolling by reinstalling touchpad driver.
Touchpad driver for Vista:
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39534.exe
Touchpad driver for Windows 7:
ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44940.exe
Mar 09, 2010 | Compaq Presario CQ60-220US PC Laptop
Insert smart card into reader
Just give pressue near touchpad and press hardly for 2 or 3 minutes and switch on. This will get solved
Aug 18, 2009 | HP Compaq nc6000 Notebook
Synaptics touchpad mouse will not move cursor
Update synaptics driver from Hp.com that should fix the issue
May 16, 2009 | HP Compaq nc6220 Notebook
How to remove keyboard
Remove (larger) screws from the underside that have a keyboard icon next to them.
Between some of the f-keys are 4 small black strips, these are the restaining clips; gently push them towards the bottom of the keyboard. Once all 4 have been pushed downwars, lift from just above the f-keys and the keyboard will detach.
Be gentle as the connections between the keyboard and the system board will come away fairly easily and are fiddly (if easy) to put back in place.
Oct 07, 2008 | HP Compaq nc6220 Notebook
How to disable touchpad
go into control panel..then under mouse..device settings..and there should be a tab that lets you disable it.
Aug 14, 2008 | HP Compaq nc6220 Notebook
Open Questions:
Computers & Internet Logo
565 people viewed this question
David Payne
David Payne
