jena would indicate an older model..if the x-bar is bent then when it is straightened it will crack..hope that is not the problem...sometimes the little pin could fall out and then the center wheel would just turn and nothing would move..if i can help [email protected]
There are no recorded serial numbers for Zeiss binoculars made in West Germany or those made by Zeiss after the fall of the berlin wall. The newer numbers have been a mystery to collectors and so far no one has attempted to publish a list. I have newer models with lower serial numbers than older models in my collection.
Bausch & Lomb was purchased by Bushnell in the 70's. Your elites are Japanese made and considered quite a good binocular. Bushnell continued to make the same binoculars bearing the Elite name but replaced B&L with Bushnell. The current elites are different shaped. You could contact Bushnell or you could go to a store in your area that may stock the older Bushnell Elites and try and see if the eyecups fit.
The East German Notarems were a little fragile when compared to their West German counterparts. They didn't require too much of a knock to get them out of alignment. To collimate them you need a device called a collimator and its not something you do at home. The Notarem is not an easy unit to take apart. It has a unique locking dioptre ring that is mated with the central focus.
They are definately worth fixing. Not cheap but then again they are not a cheap binocular. You should consult an optical shop in the country where you live. They may know of someone who can fix this. If you are in the UK or don't mind sending the binoculars for repair Kay Optical in the UK has an enviable reputation for repairing old binoculars.
sounds like they dropped hard. there should be lock rings floating around inside. if you can get the front objective ring off, the next lock ring,then the objective should come ouy and you can reset the inside lock ring.....any questions give me a call.........larry @reichinstruments.com
