Could it be a F-150 instead?
Ford Engine Bolt Torque Chart
Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec. Fastener TypeTorque Spec
Main cap bolts
60-70 ft-lbs
Outer main cap bolts
35-40 ft-lbs.
Connecting rod bolts
(40-45 ft-lbs. for 289 HP & Boss 302)
Cylinder head bolts
65-72 ft-lbs.
Rocker arms
17-23 ft-lbs.
Intake manifold bolts
23-25 ft-lbs
Oil pump bolt
23-28 ft-lbs.
Cam bolts
40-45 ft-lbs.
Cam thrust plate bolts
8-10 ft-lbs.
Harmonic damper bolts
70-90 ft-lbs.
Flywheel / flex-plate bolts
75-85 ft-lbs.
Pressure plate bolts
35 ft-lbs.
Front cover bolts
12-15 ft-lbs.
351W Torque Spec. Fastener TypeTorque Spec
Main cap bolts
95-105 ft-lbs
40-45 ft-lbs.
Cylinder head bolts
90-100 ft-lbs.
Rocker arms
17-23 ft-lbs.
23-25 ft-lbs.
Oil pump bolts
23-28 ft-lbs.
Cam bolts
40-45 ft-lbs.
8-10 ft-lbs.
70-90 ft-lbs.
75-85 ft-lbs.
35 ft-lbs.
Front cover bolts
12-15 ft-lbs.
351C, 351M Torque Spec. Fastener TypeTorque Spec
Main cap bolts
95-105 ft-lbs.
40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C)
Cylinder head bolts
105 ft-lbs. (125 ft-lbs. For Boss 351C)
Rocker arms (non-adjustable)
5/16in. intake manifold bolts
21-25 ft-lbs.
3/8in. intake manifold bolts
28-23 ft-lbs
Oil pump bolt
25 ft-lbs.
Cam bolts
40-45 ft-lbs.
9-12 ft-lbs.
70-90 ft-lbs.
75-85 ft-lbs.
35 ft-lbs.
Front cover bolts
12-18 ft-lbs.
360, 390, 406, 427, 428FE Torque Spec. Fastener TypeTorque Spec
Main cap bolts
95-105 ft-lbs.
Crossbolts for 406-427
40 ft-lbs.
40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427)
Cylinder head bolts
80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427)
Rocker arm shaft bolts
40-45 ft-lbs.
32-35 ft-lbs.
Oil pump bolt
12-15 ft-lbs.
Cam bolts
40-45 ft-lbs.
70-90 ft-lbs.
75-85 ft-lbs.
35 ft-lbs.
Front cover bolts
12-15 ft-lbs.
429-460 Torque Spec. Fastener TypeTorque Spec
Main cap bolts
95-105 ft-lbs
40-45 ft-lbs.
Cylinder head bolts
140 ft-lbs.
18-22 ft-lbs.
25-30 ft-lbs.
Oil pump bolt
25 ft-lbs.
Cam bolts
40-45 ft-lbs.
70-90 ft-lbs.
75-85 ft-lbs.
35 ft-lbs.
Front cover bolts
12-18 ft-lbs.
Main cap bolts
60-70 ft-lbs
35-40 ft-lbs.
Cylinder head bolts
65-72 ft-lbs.
Rocker arms
17-23 ft-lbs.
23-25 ft-lbs
Oil pump bolt
23-28 ft-lbs.
Cam bolts
40-45 ft-lbs.
8-10 ft-lbs.
70-90 ft-lbs.
75-85 ft-lbs.
35 ft-lbs.
Front cover bolts
12-15 ft-lbs.
Main cap bolts
95-105 ft-lbs
40-45 ft-lbs.
Cylinder head bolts
90-100 ft-lbs.
Rocker arms
17-23 ft-lbs.
23-25 ft-lbs.
Oil pump bolts
23-28 ft-lbs.
Cam bolts
40-45 ft-lbs.
8-10 ft-lbs.
70-90 ft-lbs.
75-85 ft-lbs.
35 ft-lbs.
Front cover bolts
12-15 ft-lbs.
Main cap bolts
95-105 ft-lbs.
Cylinder head bolts
21-25 ft-lbs.
28-23 ft-lbs
Oil pump bolt
25 ft-lbs.
Cam bolts
40-45 ft-lbs.
9-12 ft-lbs.
70-90 ft-lbs.
75-85 ft-lbs.
35 ft-lbs.
Front cover bolts
12-18 ft-lbs.
Main cap bolts
95-105 ft-lbs.
40 ft-lbs.
Cylinder head bolts
40-45 ft-lbs.
32-35 ft-lbs.
Oil pump bolt
12-15 ft-lbs.
Cam bolts
40-45 ft-lbs.
70-90 ft-lbs.
75-85 ft-lbs.
35 ft-lbs.
Front cover bolts
12-15 ft-lbs.
Main cap bolts
95-105 ft-lbs
40-45 ft-lbs.
Cylinder head bolts
140 ft-lbs.
18-22 ft-lbs.
25-30 ft-lbs.
Oil pump bolt
25 ft-lbs.
Cam bolts
40-45 ft-lbs.
70-90 ft-lbs.
75-85 ft-lbs.
35 ft-lbs.
Front cover bolts
12-18 ft-lbs.
My manual shows an 8RC for 70 and 71 and an 18RC for the 72-74
18RC valve clearance HOT IN .008 EX .014 cold spec. .007 .013 Cyl head 72-82 Ft Lbs Rocker caps 12-17 ft lbs cam bearing clearance .001-.002 cam endplay .0017-.0066 oil tube 11-16 Ft Lbs
cylinder head the torque is : step 1 55 ft-lb, step 2 65 ft-lb, step 3 85 ft-lb. Rocker arm stud nut or bolt is 17 to 23 ft-lb. and valve cover bolt 72 to 108 in-lb.
valve clearance is .014 inch for intake and exhaust with engine warm.
head torque it 21 ftlbs, then 44 ftlbs, then loosen all, torque to 89 inchlbs, then to 21ftlbs, then mark and turn the bolts an additional 60 to 65 degrees.
cyl head sub bolts torque 80 to 100 inchlbs.
thanks.
for cylinder head the torque is : step 1 55 ft-lb, step 2 65 ft-lb, step 3 85 ft-lb. Rocker arm stud nut or bolt is 17 to 23 ft-lb. and valve cover bolt 72 to 108 in-lb.
