Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My freezer wont freeze and the fridge part isn't as cold as usual
My fridge and freezer is acting up. I don't know if it is going out or what. The freezer is no longer staying cold enough to freeze anything. The fridge part is not as cold as it should be but cold enough so things wont spoil. I don't know what the problem is. Could anyone help?
  • Mike Smith
    Mike Smith May 11, 2010
    What brand and model number ? Is there frost on the rear wall of the freezer ?
  • 6,784 Answers
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device and thermostat.
Posted on Aug 28, 2009
  • 1462 Answers
SOURCE: Amana neither fridge nor freezer getting cold enough
the defrost system has failed. to get it working temporarily, take the back panel off inside the freezer. melt ice off with a hairdryer.
after that, fault can be in several areas - defrost heater, thermal fuse or the main pcb
Posted on Jun 30, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
blueextc3221
  • 15935 Answers
SOURCE: Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 25, 2009
SOURCE: Freezer wrk OK but temperature in the bottom fridge not cold
If you have a frost build up on the interior back wall of the freezer, you have a defrost issue. This would include a bad defrost control, bad heater or terminator.
If there is not a frost build up then you may have a bad evaporator fan motor.
Posted on Apr 28, 2009
I have a Whirlpool Refrigerator model # ET21PKXGW01 the freezer isn't freezing and the fridge isn't as cold as it should be (milk went bad). I did notice right before it stopped freezing/cooling I...
hey how r u today im no specialist but it sounds like a condensor fan if that fan goes your fridge will overheat not allowing proper freezing and or cooling. my family had the exact same problem and my dad was a appliance repair man so he knows about everything when it comes to this stuff..well hope i helped and congrats i hope u and your fiance go far. Jacob Winkler
Jul 16, 2012 | Refrigerators
Refrigerator side too cold
refrigerators only have one cooling system and that is for the freezer. The fridge part is cooled by sending a portion of the air from the freezer to the fridge. your fridge thermostat controls a fan that turns on and off as needed. first step is to make sure this is working, and not stuck on. turn your fridge to a somewhat warm no and open the door for a few minutes to allow the cold air out then check and see see if it gets very cold again within say an hour. if it does your fan is always on and you need to repair it. if that is working then you have to play with both freezer and fridge settings. best thing is to get a cheap thermometer and check your freezer temp. it should be around 0 to -5f if it is colder than that frigid air blowing into your fridge too cool the whole area will freeze anything close to the vent. once you have your freezer set then start adjusting your fridge. personally I have mine set at 34f knowing that some things on the top shelf will freeze. but I like my cola's COLD. so I put things like butter that are harder to freeze at that level. but if you don't want anything to freeze then a temp of 37 -39f is correct for your fridge. so it comes down to freezer temp, the amount of time the fan is on, and proximity to the vent. good luck
Nov 28, 2011 | Cars & Trucks
Whirlpool Wrn38rwg6 Freezer isn't freezing and I
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 16, 2011 | Whirlpool Refrigerators
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
Frigidaire refrigerator model # frs6r5emb8 wont get cold and freezer wont freeze. I replaced the filter and cleaned any and all dust out from the rear bottom of the refrigerator. Freeze wont get cold...
first off the freezer is cold but not cold enough?if the freezer isn't working right then the fridge is gonna be warm too,all it does is get cold in the freezer and the evap fan blows cold air into the fridge,that's it.i need you to do a few checks for me,open the freezer door,do you hear the fan blowing around,if not you could have a bad evap fan motor,next from the bottom up remove the second bin from the bottom and touch the back wall,do you feel any ice or snow on the back wall.if so you have a defrost problem,possible computer board,defrost thermostat or heater.let me know what you find.one more thing did this happen after you cleaned it or did you clean it to try to see if it would help?
May 15, 2011 | Refrigerators
Candy CPCA250 GB Freezer feezing but fridge not cold
Hello jonnyclewlow
Welcome,
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair shop diagnosed a thermostat problem. I have replaced the thermostat, Now the freezer freezes without any problems but the fridge does not go cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is
too warm. Freezer
temperature is satisfactory.
1. Fresh Food control is set too
warm.
2. Set fresh food control to a colder setting. Allow 24
hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back!
This would also cause the compressor to run none stop trying to cool the fridge!
So check your air vents in the freezer.
I'll bet you did not know they were there !
Most of us never notice!
Hope this works for you.
Please let me know that one of these solutions worked for you!
or if you have any questions.
Thank You, huuum
Please remember to leave a rating!
Oct 14, 2008 | Candy CPCA270FFK Bottom Freezer...
Refrigerator not working
Hello bobbie50,
Welcome to Fixya,
You said, After making a louder than usual grumbling noise several times today, my refrigerator is no longer cold (freezer too). Please tell me I don;t have to buy a new one. my refrigerator is not working properly. The freezer keep thing cool but will not freeze. the bottom part does a little cooling ,but not like it should.
Help me with a little info.
What is the model # and the year or age of your fridge?
Let me know right away. I'm here for you!
Huuum
Aug 04, 2008 | GE Hotpoint Top-Freezer Refrigerator
Refridgerator/Freezer will not get cold
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 21, 2008 | Refrigerators
Amana fridge with freezer on bottom
  • possible causes:
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 30, 2008 | Freezers
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
197 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
