Question about Mitsubishi VS-50605 50" Rear Projection Television
Cleaning the Inside
1) How Do I Take off the screen of the Mitsubishi V5-50605 46-50in Televison?
2) I Need to clean my mirrors (projectors?) that are on the inside of the television.
3) The horozontal lines are happening with mine too, am I doing the right thing?
Pull front speaker grill it snaps on take 5 or 6 screws out just under screen lift screen by sides straight up entire screen will come off exposing mirror
Posted on Jan 01, 2008
Why does my Mitsubishi hc5500 projector only display a blue screen but still play sound?
The unit may need cleaning. The lamp will shut off if the air flow is blocked by dust.
Aug 31, 2014 | Mitsubishi HC5500 LCD Projector
How do I get to the inside to clean my wd73640 tv ?
If you mean removing the casing ... there may be components with a residue charge that can shock you even if its unplugged, and not grounded. Does your manual mention mirror cleaning?
-GWOOD
Jul 16, 2014 | Mitsubishi WD73640
All areas that should project white are yellow could this mean bulb is getting old or maybe the settings of the compoter its hooked upto need to be chnaged please advise
If the screen is getting more yellow, that is due to either an old bulb, not producing so much high frequency light, or the blue LCD imager is dirty/burnt or the mirrors require specialist cleaning.
Cleaning the LCD units and mirrors takes about 2 hours to complete including re converging.
Hope that gives you an idea.
Dec 31, 2010 | InFocus Proxima UltraLight LS2 Multimedia...
Mitsubishi wd 62527 has very dark picture changed
Clean the small front projection mirror. That mirror can get dust on it and will cause the projected image to appear dull and dim and cleaning that mirror will usually restore the brightness and crisp details in the image.
Oct 20, 2010 | Mitsubishi WD-62725 62" Rear Projection...
How to clean a toshiba tv screen model # 50a62
snap off the fron cover its pretty tight so kind of pull hard dont worry it wont break its just snaped on tightly, after uncrew 3 screws under the screen lift up and pull out screen there will be 2 wires attached to screen, unplug them to set screen to side. dust off the projectors with dry rag, then clean mirror with windex or any window cleaning product. u are done cleaning front of Toshiba, put everything back together, then unscrew the bottom back and vaccum any dust balls u will see inside T.V. u r now done! let me know how it went.
Jan 29, 2010 | Toshiba 50A62 50" Rear Projection...
Does the front panal around the screen of my Mitsubishi VS-50707 come off for cleaning behind it?
Yes, front screen can be removed to clean projection mirror and picture tubes lenses.
Remove speaker grille, pull them to remove.
There are 3 screws at bottom of front screen, remove them. There are few wire harness plugs need to be disconnect to remove completely front screen.
Below exploded view of Mitsubishi VS-50607 will help you to remove front screen to clean inside. Be careful while removing screen.
Oct 23, 2009 | Mitsubishi Televison & Video
How do i clean the projectors and screens of my mitsubishi vs-50607 tv
Pull the Front Bottom panel off under screen will be screws that hol pn screen remove all of them then lift up on screen anf remove it Now you should be where Mirror and Tubes Clean all lenses and mirror with windex.
Sep 19, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Hitachi 51F500 Cleaning
the trim on the screen pops off and behind that trim are screws that hold the screen in place...once you remove the screen you can clean the lenses and the mirror and maybe get a cleaner clearer image
Feb 18, 2009 | Hitachi 51F500 51" Rear Projection...
Mirror
There is black insulating foam that surrounds the projector and it may be displaced to one side.This leaves about an 1 inch opening around the projector lens and that could be the source of the problem,dust being blown into the compartment with the mirrors.
Cleaned the mirrors really well and used double stick tape to reattach the foam to the plastic frame and this will closed off the opening that maybe letting the dust into the mirrored area of the TV.
Nov 12, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
126 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
