Question about Philips 60PP9363 60" Rear Projection HDTV-Ready Television
Same problem here I think??
I looked inside and found the projector bulb had blew up. Would I need a repair kit as well as a new bulb or is it possible the bulb blew up on its own will? Any suggestions would be most helpful! Thanks!
  • crazy_house Jul 20, 2009
    Thanks for the info. Now if I could find one, I would have it made! LOL Thanks Again!
  • 165 Answers
Its possible its just the bulb im almost sure it is
Posted on Jul 20, 2009
My argus 300 projector bulb blew new one won't work
yes could have been a power surge at the time, or fan cooler packed it in, the internal housing inside the Projector would have been too hot with the bulb inside it cooling down without the fan, i would double check all parts near the lamp housing and check to see they have not melted or burnt, also worth checking the fuse as well should be a T-250 Fuse bulb
Apr 23, 2017 | Argus Vintage Cameras Inc Projector Model...
Hc1500 projector will not turn on
Sounds like the lamp. The only way to really check it is to either put a new bulb in or put the old bulb in a different projector. Neither of which probably help you at this point. But, it does sound like the lamp is blown.
Mar 30, 2014 | Mitsubishi HC1500 DLP Projector
Light bulb burned out
Did you have a hinge kit recently replaced? If so call them back they missed something. If not, look into the light circuit a if it goes to ground this light issue would happen. Most of these issues I found in the upper section behind the upper grills. I hope this helps
Dec 25, 2013 | Viking Professional VCBB363SS Stainless...
Optoma hd20 fan shut down
I put this here because when I was experiencing the same issue I found there was very little info online for this topic. Optoma asked me $125 just to take a look at my out of warranty hd20 projector after I started getting the dreaded "fan failure" error message, I got this error mesage after replacing the bulb (its important to note that the bulb did explode in the unit so some of the debris may have lodged in the fan.) Optoma also kept saying stuff like motherboard issues and fan sensors on the phone. Everything I've read has said the repair price is so high on these issues that it is better to upgrade to a new projector so I resigned myself to doing that very thing. Then I ran up on this video and thought what the heck. So I took the plunge and popped the case off and sure enough the same little fan was stuck and covered with dust. I gently moved it with a screw driver and blew all the dust out of it. Plugged it back in and I'm experiencing glorious 135" hd once again.
Feb 28, 2012 | Optoma HD20 DLP Projector
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
My projector blew a bulb after installation what the problem generic bulb
Hello :
Check out the Power supply to the lamp . It must not be high . . Check if the voltages are correct to the lamp's unit and it's PCB [printed circuit board]. I recommend using a service manual .
Check for manual here please :
Sharp DT-100 Multimedia Projector manual .
Here is how to replace a projector's bulb correctly :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp
I hope this will help .
rate please !
Mar 21, 2010 | Sharp DT-100 Multimedia Projector
Loud Bang and Projector no londger works
If the internal fuse has blown, if you connect the power lead loosely and move it about, you should not be able to hear any crackling sound of electricity. If you do then it is more likely something else other that the internal fuse. Generally, a loud bang is either the fuse or lamp.
Sep 25, 2008 | 3M MP 8749 Multimedia Projector
250V T6.3AH Slow Blo Fuse
Depending upon the way in which the lamp finally smoked, it is not unusual for the feeder fuse to blow. Replace the fuse and try the projector. As long as you haev a new lamp, it should work OK.
Dan
Sep 11, 2008 | NEC VT670 Multimedia Projector
Blending Colors/Flickering Display
Hi SmartMex
This in not a lamp problem , but rather a Mainboard issue.
You will have to take it to a Service Centre to either be repaired or replaced.
Apr 17, 2008 | Optoma EzPro 739 Multimedia Projector
Philips 60PP9363 60" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
